05-14-2018 10:43 PM - edited 03-18-2019 02:06 PM
I have a TCS server that's due for replacement.
Looking to replace it with CMS Recorder.
Can CMS Recorder be deployed stand-alone, or musty it be in conjunction with a CMS Call Bridge service?
VC calls are scheduled via TMS, and the TCS server added into the call (all VC units have multi-site option). Is the CMS Recorder a similar procedure from a user perspective, or are users going to need to follow a new process?
Does anyone have any other suggestions? I did consider vBrick, but the price will kill that idea.
Thanks.
Solved! Go to Solution.
05-15-2018 08:17 AM
05-14-2018 11:33 PM
vBrick Rev is the solution if you want to migrate all of your existing content from the TCSes on to the new platform as it's supported by both TCS and CMS.
Please remember to mark helpful responses and to set your question as answered if appropriate.
05-16-2018 06:05 PM
Thanks Wayne.
No need to migrate anything from TCS. It's all currently removed manually and put onto a SharePoint server.
05-15-2018 08:17 AM
05-16-2018 06:08 PM
Thanks Patrick,
Looks like I'll need to build up a CMS solution.
There is no requirement for live streams.
Saved content will be manually transferred onto a SharePoint server, so no need for a separate viewing solution.
12-17-2018 09:30 AM
Wait till you see the price of a CMS server and CMS Recorder - not to mention the series of licenses yearly. Then take a look at other solutions, they may not seem that high.
