TelePresence Conductor Clustering over WAN
Hi Cisco,
We want to deploy Clustering of 3 Conductor servers (2 local) and 1 over the WAN in a different DC.
Based on clustering guide 2.x and 3.x it states we need 30 ms RTT between Conductor servers, currently we have 50 ms RTT. Does Conductor 3.0 supports higher RTT? What are the implications of deploying Conductor with higher RTT?
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/conductor/config_guide/xc3-0_docs/TelePresence-Conductor-Clustering-Unified-CM-Deployment-Guide-XC3-0.pdf
Patrick Sparkman
The round-trip time is still the same, 30ms, and hasn't changed.
As far as any issues you might come across if you go over the round-trip time, take a look at this discussion conductor-clustering-and-latency.
Patrick Sparkman
Thanks Patrick,
I'm surprised this RTT is too low since Conductor just handle mostly signaling. Probably some under the hood DB requirement. I'm thinking of having 2 separate clusters, each in a different Data Center monitoring the same TPS. (Active/Standby), but CUCM will be configured to only select the "standby cluster"  when the "closest" Conductor cluster is unreachable.
Do you know if TPS 4.X in remote manage mode supports this scenario?
I've never heard of anyone deploying Conductor in such a way.
