11-13-2013 07:02 PM - edited 03-18-2019 02:08 AM
Hi All,
Im currently working on a POC with this 3rd part endpoint. The scenario going on is, this 3rd party endpoint want make a H.323 point-to-point call to CTS 3010 registered to CUCM v8.6. But the call never reach the CTS, does this has anything to do with TIP?
Previous scenario we tested was:
Looking forward for opinion from you guys based on your experience dealing with 3rd party endpoint integrated with TP.
Hidzwan
11-20-2013 01:32 PM
Hi Hidzwan,
Do you have the full call path for this scenario from end to end?
The CTS won't support an H.323 call directly, is a VCS interworking this call?
What is the 3rd party endpoint we're using?
Can we make a SIP call that succeeds?
We'll probably need to get logs along the call path to see where the signalling isn't working if it's not getting to the CUCM.
Tyler
11-20-2013 10:53 PM
Dear Tyler,
First of all, thanks for your reply.
Here is my response to your reply;
- Don't understand this, is it something i can generate from anywhere to get the call path?
- Yes, i have Internet VCSE in place as the gateway for H.323 call. Translated the H.323 to SIP and send the call to CUCM.
- The brand called AVer.
- No. Even the SIP calls failed (got dropped when we push answer button.
Hidzwan
