5771
ciscomoderator
Community Manager
Title: Ask the Expert: Cisco TelePresence Management Suite Extension for Microsoft Exchange
Read the bioWith Tim Walker
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn from Cisco expert Tim Walker on how to install and upgrade the Cisco TelePresence Management Suite Extension for Microsoft Exchange (TMSXE 3.0). You can also ask troubleshooting questions as well as best practices.
Tim Walker is an escalation engineer within the Cisco TelePresence Solutions Group (TSG) in Cisco’s Technical Assistance Center, Reston, Virginia. Before joining Cisco, he worked at TANDBERG as a product support engineer (SME) for TANDBERG TelePresence Management Suite (TMS) products, TMS Microsoft Exchange integration, and Lotus Notes integration products. Tim has over 15 years of experience as a systems and network administrator and holds several TANDBERG certifications.
Remember to use the rating system to let Tim know if you have received an adequate response.
Tim might not be able to answer each question due to the volume expected during this event. Remember that you can continue the conversation on the  Collaboration, Voice and Video sub-community TelePresence discussion forum shortly after the event. This event lasts through July 6, 2012. Visit this forum often to view responses to your questions and the questions of other community members.
This event is the continuation from the live webcast that Tim gave on Tuesday June 26th. You can review the slides of the presentation here.
Related links:
Video
FAQ Document
23 REPLIES 23
Hello all,
Thank you for your interest on this topic. The recording of the video is posted at  https://supportforums.cisco.com/videos/4009.
There is also a FAQ document with all the questions and answers from the live event.. You can access the document at  https://supportforums.cisco.com/docs/DOC-25574
If you want to see the slides of the live presentation, access those at  https://supportforums.cisco.com/docs/DOC-25186
Kind Regards,
Cisco Moderator
Tim,
I mean the user that can be created here: Systems -> Provisioning -> Directory  in Catalog->Local Directory
The user that you created is under the Provisioning Directory.  Although there is a table in the TMS database that stores a portion of the Provisioning Directory information user account information is stored in the OpenDS database if you are using the Legacy TMS Agent and in the TMPE database if you are using the Provisioning Extensions.
If you are using the Legacy TMS Agent then you would of had to also taken a TMS Agent back under Administrative Tools>Configuration>TMS Agent Settings and restored that along with restoring the TMS database.  These are two separate databases.
If you are having issues with this then I would suggest that you open a case with the Cisco Telepresence Support Group and we can take a look into this for you.
Tim
Hi Tim.
I've made some testing and have another question.
First of all I made a TMS Agent backup and than I deleted a user.
Than I disabled replication on VCS Control TMS Agent;
Than I cleared the list of Replicating agents.
Than I complited the restore TMS-Agent.
After that I saw the deleted user in the Provisioning Directory. So the user was restored.
But when I enabled replication on VCS Control TMS agent the user disappeared again.
Is it correct behavior?
Andrii
Hello Tim,
I've found the next information in the
Cisco_TMS_Agent_Legacy_Provisioning_Guide_13-2:
"The Cisco TMS Agent replicates through a multi-master replication process, meaning that no one database is the master of all. The Cisco TMS Agents on the Cisco TMSs (if in a Cisco TMS redundant setup) and Cisco VCSs (if in a cluster) continually check with one another for changes and differences between them. All provisioning configuration changes must be made via the Cisco TMS Provisioning Directory UI."
So, it seems like after restore TMS thinks that VCS Control has more actual database (without interesting user) and TMS replicates provisioning user database from the VCS Control.
Could you please give me the right algorithm to restore user directory?
Andrii
Yes it was recorded.  We are working on getting it uploaded.
The recording can be viewed by going to the below link:
If you have questions after reviewing the recording feel free to post them here.
Tim
vipersl65
Enthusiast
Tim,  I went thru your slide deck presentation for TMSXE and it is Exchange centric.  While I dont blame you since Exchange controls the market, a Domino or Lotus Notes integration with TMS falls into my plate and now I am trying to get as much documentation or skills for this.
Where are the slides or docs for Domino or Notes integration?
thanks
Anacleto,
Kind Regards,
Cisco Moderator
We have not provided an Ask the Expert webinar on the topic of the Lotus Notes integration with TMS.  If this is something that you would be interested in seeing Cisco offer please post that here and we will see about offering this as part of the Ask the Expert Webinar series.
I would be interested in providing this as this is a product that I am also a SME.
The documentation for the TMS Lotus Notes integration can be downloaded from the Cisco.com website as well as the installer.
Tim
Create
Recognize Your Peers
Content for Community-Ad
