05-31-2012 04:23 AM - edited 03-17-2019 11:15 PM
One of our customers is using some Polycom VSXes as well as Cisco VC systems. They created a phonebook on Cisco TMS. This phonebook also includes some folders. On C20s, they can see the folders on the phonebook. But on the Polycom VSXes, they can not see the folders. They see all addresses in the same directory in order from A to Z. Do you know it is possible to seperate with folders on VSX or not? If so how?
Best regards,
Tufan
Solved! Go to Solution.
05-31-2012 07:27 AM
The polycom units does not support this unless they have included it in some new software at least they did not support this before. Only a flat phonebook like you see. Use cisco endpoints
05-31-2012 07:27 AM
05-31-2012 07:38 AM
Actually they are replacing Polycom with Cisco. They have bought 90 C20s. But they don't want to throw Polycoms away immediately. So I want to help them now. Is there someone who experienced this with new software?
02-25-2014 05:07 AM
on HDX series it is possible to see the phonebook wih folders,
but for vsx series it is over.
take care Tufan.
