Cisco Community Designated VIP Class of 2020
2551
Highlighted
Beginner
TMS connection
We supervise codec's using TMS.
TMS can not connect the codec after network of codec changed .
We are checking network..
What is port that TMS use when TMS give phonebook to Codec and connect to codec?
then dose TMS use SNMP port only(161,162)? or other port?
i saw information of manual
http://www.cisco.com/en/US/docs/telepresence/infrastructure/tms/install_guide/Cisco_TMS_install_guide_13-2.pdf
Everyone's tags (2)
2 ACCEPTED SOLUTIONS
Engager
Re: TMS connection
I would open for Tandberg/Cisco endpoints:
form TMS to the endpoint:
TCP: 20,21,22,23,57,80,443
UDP: 161
from the endpoint to the TMS
TCP: 80, 443
UDP: 162
The corporate phonebook for MXP and TC systems will use port http=tcp/80 or https=tcp/443
depending on what you have configured or whats aailable
Beginner
TMS connection
Martin,
Where can i find settings for TCP & UDP Ports in TMS ??
8 REPLIES 8
Engager
Re: TMS connection
UDP: 161
TCP: 80, 443
UDP: 162
Re: TMS connection
For Aethra and Polycom endpoints are the same ports listed above?
Re: TMS connection
Yes, TMS provides the phonebook via http/s 80/443 as Martin is saying. So assuming the endpoints support phonebooks from tms ( dont know about aethra, but certain polycoms does) they have to use the same ports to get the phonebook.
Beginner
Re: TMS connection
For polycom, I have to open FTP (21)  for phonebook (polycom vsx)
Beginner
TMS connection
Martin,
Beginner
TMS connection
martin
thanks for your answer
regard
Beginner
TMS connection
Our issue is solved by adjusting MTU size of TMS.(1500->1460)
TMS OS: Windows 2003
is it no problem?
Beginner
TMS connection
For polycom below ports are required for phonebook:
TCP Port 3361 – Required for Global Address Books - For 1st and 2nd Gen
TCP Port 3601 – Outbound from device Required for Global Address Books - For VSX, HDX, IPower and ViaVideo I & II Series.
Sumeet Rakesh
Content for Community-Ad
FusionCharts will render here
