Walkthrough Wednesdays
456
gpsriramdc
Enthusiast
TMS Installation - External SQL
Hi !
We are installing the TMS 15.13 and database is on external SQL server with Windows based authentication. SQL Native client already installed , Windows Account login is verified successfully but still getting the error as login failed. How we can troubleshoot ?
6 REPLIES 6
gpsriramdc
Enthusiast
Did you change the IIS application identity?
Please refer to the following document: Configure TMS to  Use Windows Authentication for External SQL Server - Cisco
if you have already done the above, please share the SQL version that you have installed?
Hi Shalid,
This is the fresh installation. I guess TMS IIS pool created only after the installation.
Point to consider
  • Mixed-mode authentication must be enabled on the SQL during the TMS installation
  • the SQL user should have the dbcreator and securityadmin server roles.
  • TCP/IP should be enabled
Eric Ingram
Enthusiast
I'm no longer using TMS but I when I set this up the same way you are trying I recall a specific version of SQL native client was required.  It was in the troubleshooting section of the install guide.  Maybe uninstall and reinstall it.
Also make sure ports between TMS Windows server and external SQL are allowed to communicate.  I also had that issue due to some data center requirements.
Zac Colton
During the installation process of TMS, SQL based credentials must be used. TMS can then be set to use Windows based credentials *afterwards*.
Content for Community-Ad
Spotlight Awards 2021
