06-23-2020 08:51 AM
I have a customer that uses both WebEx and on-premise CMS meetings and would like to know if they can use TMS. I'm wondering if I can set up TMS with both WebEx enablement and CMS.
Solved! Go to Solution.
06-23-2020 05:08 PM - edited 06-23-2020 05:09 PM
If the customer is using Office 365, then you can use Webex Hybrid Calendar w/TMS to deploy '@meet' scheduling for CMS and '@webex' to book Webex Meetings.
If the customer is using MS Exchange, then @meet isn't supported, instead you can use TMS, TMSXE and Webex Productivity Tools. Deploy CMS w/TMS and TMSXE as normal, with the "Preferred MCU Type in Routing" set as "Cisco Meeting Server". All meetings that include two or more VC endpoints and/or include the scheduling mailbox will then book a CMS conference with OBTP. You can then add the Webex Productivity Tools Outlook plugin, if a user adds Webex to a conference via this method then TMS will schedule the OBTP conference as an "Externally Hosted" meeting using the Webex SIP URI.
Hybrid Calendar w/TMS: https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cloudCollaboration/spark/hybridservices/calendarservice/cmgt_b_deploy-spark-hybrid-calendar-service/cmgt_b_deploy-spark-hybrid-calendar-service_chapter_010010.html
TMSXE Deployment Guide:
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tmsxe/install_guide/Cisco-TMSXE-Deployment-Guide-5-11.pdf
06-23-2020 08:54 AM
What are they looking to achieve with TMS?? Scheduling?? OBTP??
06-23-2020 09:26 AM
06-23-2020 06:00 PM
Thank you! I appreciate the confirmation.
