11-18-2012 05:04 PM - edited 03-18-2019 12:09 AM
Does anyone know when TMSPE will be updated to be compatiable with the most recent version of Java 7, or whatever version is released at the current time. I read in the data sheet, that it requires Java 6, and I think somewhere that the latest supported version is Java 6 Update 33.
Solved! Go to Solution.
11-19-2012 03:13 AM
There could still be some issues with using TMSPE 1.0 with Java 7, so Java 6 update 33 is the recommended Java version for now.
Official support for Java 7 is scheduled for the next TMSPE release, with a target release date in April.
Kjetil
11-18-2012 06:00 PM
Hi Patrick, Yes as of now TMSPE works fine with Java 6 Updates.
11-19-2012 03:13 AM
Kjetil
11-19-2012 08:35 AM
Kjetil is correct and current TMSPE Deployment Guide specifically states:
Version 6 (32-bit), update 33 recommended. Updates 4-33 supported
And yes, official support for Java 7 will be coming in the next TMSPE release
04-01-2013 06:39 PM
What is the official date of release? Because of the exploitations of Java, our security folks are consistantly updating Java versions, and the next one is will be Java 7.0 update 17. We are currently on Java 7 version 13 and we are having problems.
04-01-2013 10:28 PM
Hi, its difficult give out specific dates of release as things might come up and postpone the release.
/Magnus
