On running the Migration tool after the TMSPE install, I get 1 warning, and 1 error. It seems from below that {ame} is the problem here but where do I edit it out with the recommended replacements? I can't see {ame} anywhere in the FindMe Provisioning template or anywhere else in TMS...
WARNING:
Invalid caller id pattern for group mycompany could not be migrated: {ame}@mycompany.co.uk. Legal replacement values are {mobile_phone} and {office_phone}.
ERROR:
Failed to create group for {display_name=[mycompany], display_name_pattern=[{display_name}], video_uri_pattern_inherited=[false], video_uri_pattern=[{ame}@mycompany.co.uk], device_uri_pattern=[{ame}.{device.model}@mycompany.co.uk], device_uri_pattern_inherited=[false]} URL: /groups The exception returned from API was The argument
video_uri_pattern={ame}@mycompany.co.uk
is invalid Status: InvalidArgument Status Code: 1005.
The exception message is: POST
http://localhost:8788/ur/groups returned a response status of 400 Bad Request
video_uri_pattern={ame}@mycompany.co.uk is invalid Status: InvalidArgument Status Code: 1005.
Can anyone shed some light on this?
Tom
Solved! Go to Solution.
You could try to remove the device uri pattern and the findme patterns and then try to do the migration again. If its successful you can re-populate these fields easy once tmspe is up and running.
/Magnus
Hi, it seems like its complaining about the caller id which is configured in the findme setting in tms provisioning directory on one of the groups.
If you go to the tms agent settings
In tms do you "hide" your findme Setting? If so try to "unhide" and then go back to the prov dir and see if you can see anything here now. Ame is part ofthe word usernAME or firstnAME or lastnAME is there something that might cause this placeholder to be "misread" by the migration tool?
Just throwing some thoughts..
/Magnus
Thanks for the advice - FindMe is not hidden in TMS Agent settings, and we only have one FindMe template:
We do have some unused XML templates referring to older versions - the provisioning guide recommended removing them but I can't see how.
Tom
/Magnus
Replication is disabled i assume so it wont affect the database on the vcs.
/Magnus
Yes correct - I'll give it a try
And it worked...migration now complete!
I had to re-add the templates which was no bad thing since there are a few changes e.g. {mobilephone} is now {mobile_phone} in the new TMSPE...
Thanks again.
Tom
Great
Thanks for letting us know
/Magnus
