A new version of TMSPE is generally released with each version of TMS, the first page of the TMSPE Deployment Guides note the TMS and Extension versions that's been released together. I'd recommend you run the current version, or close to it, but I don't think it would be an issue if you ran older versions unless something specifically calls out for a specific version.
I just finished to write an interesting document, instead of multi SAN Certificate, this document shows how to configure different certificates for WebBridge and CallBridge using different CA Server.
As mentioned previously in my previous article and following the same idea of certificate pinning in Cisco Meeting Server, to demonstrate this concept added since version 3.0. I used two different CA to sign :1-The WebBridge certificate with CA's certific...
view more
Certificate pinning is introduced on cisco meeting server starting in CMS 3.0 to help prevent man in the middle attack.But what is the Certificate Pinning?Traditionally, SSL Handshake consists on the validation of the server's certificate, let's say colla...
view more
In a Clustering over the WAN deployment, securing the ICCS (Intra-Cluster Communication Signaling) traversing the WAN can be a requirement. The IPSEC VPN Policy between nodes can be configured to secure the ICCS Traffic.To quickly verify that the IPSEC is...
view more
Attracted by the concept of dial plan and the passion of writing, I launched a challenge to write a workbook with practical scenarios covering in details this concept, the result is a workbook with 30 practice labs treating many components such route patt...
view more
