Walkthrough Wednesdays
542
Ahmed habib
Participant
TMSXE Schedule meeting through Outlook doesn't send meeting info to participants
I have TMSXE, When I schedule meeting through outlook and put Endpoint mail, CMS Virtual mail an participants.
The meeting info and link join only sent to me and othe partcipants receive only invitation meeting to accept without any data about the meeting.
Also I want to enable the add-on on Outlook to schedule in the room endpoint quickly
1 ACCEPTED SOLUTION
@Oruc AkpinarThank you for your answer.
I am already adding scheduling mailbox in the meeting but with no luck
I got information from Cisco TAC that is not applicable
The behaviour you see is expected, TMSXE will send meeting info to organizer only and not to the other mail on the invite. This is describe in the installation guide:
You can find this in https://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tmsxe/install_guide/Cisco-TMSXE-Deployment-Guide-5-10.pdf at page 21.
It’s up to the organizer to forward the invite with the link.
This is a restriction of TMSXE, the TMSXE plugin is considering only the room mailbox and the organizer of the meeting. The other participants are just ignored, that’s why you will have to forward the mail received by TMSXE with the meeting details to the other participants.
I know this is a limitation, but this is by design in the product
5 REPLIES 5
Oruc Akpinar
Beginner
Can you try to put more than one room endpoint mail address and let's try again. Probably everyone will receive meeting info, link and join details.
If you don't add the second room or if you want to use only single room endpoint into your meeting request you need to configure scheduling mailbox. (like a virtual room endpoint). You can find this configuration on the TMSXE application that "Scheduling Mailbox" tab.
After this configuration, while you create a meeting request you need to add this mailbox as a participant. The main reason behind this has to be a minimum two-room for the meeting. Because of that, you need to add a virtual room as a participant.
you can find more details bellow link / page=15
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tmsxe/install_guide/Cisco-TMSXE-Deployment-Guide-5-3.pdf
regards.
Please rate all posts as helpful, if applicable.
Hello Ahmed,
Can you please share with me the configuration steps to create the scheduling mailbox? I have the CMS and Jabber users.
Please find attached may help you @abdul rasheed
Thanks Ahmed,
Really helpful.
Content for Community-Ad
Spotlight Awards 2021
