Highlighted
Beginner
Touch 8 (CTS-CTRL-DV8) Cable?
Hi community,
Just quick question for everyone. What is the name (type) of the connector on the end of the Touch 8. It kind of looks like RJ45 but has clips on side (?).
Thank in advance.
5 REPLIES 5
Might be a Cisco prosperity
Might be a Cisco prosperity cable used for the Touch 8.  I looked through the data sheets and install guides, there is no mention of what connector type that is.  What are you asking for?
Highlighted
Beginner
Thank you Patrick! Just need
Thank you Patrick! Just need to identify it on drawing. I did a call out with description but it just made me curious as to what Cisco calls it. Further on the PoE injector (POE13U-130-R) has female end, what is that called?
Am I correct in assuming it is serial?
Highlighted
VIP Advisor
No, it's an Ethernet connection, not a serial connection.  I don't know that either of the connectors has a common name, they're a proprietary connector made by AMP for the touch panels.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Highlighted
Beginner
Thank you Wayne. Will leave
Thank you Wayne. Will leave question open for a little bit see if anyone comes up with as you said the “common name”.
Thank you for clearing up the connection type. Good stuff…
GB
Highlighted
Beginner
Re: Touch 8 (CTS-CTRL-DV8) Cable?
Better late than never....
It is an SDL connector, 50 series by AMP
Mike
