Traversal Clients on Cisco VCS
tony.norberg
We use a hierarchical solution on the VCS infrastructure and on the master VCS´s we currently have one Traversal Client pointing to a VCS-E making it possible to do outbound calls over Internet.
Now we need to install a second VCS-E and we have some difficulties getting the two VCS´s to connect.
The H.323 port we use for the first VCS-E connection is Assent-6001, should we use the same port for the second VCS-E or do we have to use another port for an example 6002 ?
Tony
Alok Jaiswal
Hi Tony,
are this VCS-E in a cluster?  i hope not right?
if not, then use a different port such as 6002 as you mentioned.
Cheers
Alok
