Two Touch10 controlling the same Webex Roomkit Plus
fabiofgarcia
Is it possible to have 2 Touch10 paired to the same Webex Roomkit Plus?
We would like to place 2 Touch10 on a big conference table room.
Tks
Wayne DeNardi
As @PJMack said, yes, the endpoint can support multiple touch panels with the "Peripherals Profile TouchPanels" setting.  Please note though, as mentioned in the Admin guide, only one Cisco touch controller is officially supported.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
PJMack
Level 7
Level 7
If you go into configuration, peripherals, your options for "Profile Touch Panels" go all the way from 0-5, so you should be all set.
Wayne DeNardi
Wayne
