UCM h323 gateway - sip trunk
dan.letkeman
Level 4
Level 4
I have a sip trunk connected and working on a ccme router.  I have one phone registered to the router and I can make outgoing calls via the sip trunk.
What I want to do is move that phone back to the UCM server and place calls from the UCM server to the router and out the sip trunk.  I have the router setup as a gateway, like my other routers, and I have an h323 connection to it as I see the call being setup in the debugs.  But it doesn't seem to be making its way out of the router.  Any ideas why I just get a fast busy?
Here is the relevent config and the debug messages:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
h323
  emptycapability
  h225 id-passthru
  h245 passthru tcsnonstd-passthru
sip
  registrar server expires max 3600 min 600
  redirect contact order best-match
voice class h323 1
  h225 timeout tcp establish 3
interface Loopback0
ip address 10.22.22.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.22.22.1
interface FastEthernet0/1
ip address 188.188.188.1 255.255.255.192
ip access-group firewall in
ip nat outside
duplex auto
speed auto
no cdp enable
dial-peer voice 900 voip
destination-pattern 1[2-9]..[2-9]......
session protocol sipv2
session target dns:did.voip.provider.net
dtmf-relay sip-notify rtp-nte
codec g711ulaw
no vad
gateway
timer receive-rtp 1200
sip-ua
credentials username 1111 password 7 1111 realm did.voip.provider.net
authentication username 1111 password 7 1111 realm did.voip.provider.net
nat symmetric role passive
nat symmetric check-media-src
no remote-party-id
no redirection
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 5
timers trying 1000
timers connect 100
timers register 250
registrar dns:did.voip.provider.net expires 3600
sip-server dns:did.voip.provider.net
no suspend-resume
telephony-service
max-ephones 10
max-dn 100
ip source-address 10.22.22.1 port 2000
calling-number local secondary
timeouts interdigit 2
system message CCME-SIP-TRUNK-TEST
max-conferences 4 gain -6
web admin system name cisco secret 5 1111
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 9
create cnf-files version-stamp 7960 Mar 27 2011 17:04:14
Apr 21 23:11:44.671: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type SETUPIND_CHOSEN
Apr 21 23:11:44.671: //1393/803DF3B70200/H323/setup_ind: callingNumber[5555551111] calledNumber[15555551234]
Apr 21 23:11:44.671: //1393/803DF3B70200/H323/setup_ind: ---- calling IE present
Apr 21 23:11:44.671: //1393/803DF3B70200/H323/setup_ind: ====== PI = 0
Apr 21 23:11:44.671: //1393/803DF3B70200/H323/setup_ind: Receive: infoXCap 0
Apr 21 23:11:44.671: //1393/803DF3B70200/H323/setup_ind: Receive: infoXCap ccb 0
Apr 21 23:11:44.671: //1393/803DF3B70200/H323/setup_ind:setup_ind: is_overlap = 0, info_complete = 0
Apr 21 23:11:44.671: //1393/803DF3B70200/H323/setup_ind: Call Manager detected
Apr 21 23:11:44.671: //1393/803DF3B70200/H323/cch323_h225_receiver: SETUPIND_CHOSEN: src address = 10.22.22.1; dest address = 10.1.1.11
Apr 21 23:11:44.671: //1393/803DF3B70200/H323/run_h225_sm: Received event H225_EV_SETUP_IND while at state H225_IDLE
Apr 21 23:11:44.671: //1393/803DF3B70200/H323/common_idle_setupInd_hdlr: no match is found
Apr 21 23:11:44.671: //1393/803DF3B70200/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_SETUP state
Apr 21 23:11:44.675: //1393/803DF3B70200/H323/cch323_create_incoming_callinfo_block: peer is NULL - may affect modem pass through! ccb: 4C99EBE0, ccNewCallInfo 499C4758
Apr 21 23:11:44.675: //1393/803DF3B70200/H323/cch323_create_incoming_callinfo_block: Calling Party is CCM
Apr 21 23:11:44.675: //1393/803DF3B70200/H323/cch323_h225_handle_deferred_ind: UnBuffering deferred indications
Apr 21 23:11:44.679: //1393/803DF3B70200/H323/run_h225_sm: Received event H225_EV_RELEASE while at state H225_SETUP
Apr 21 23:11:44.679: //1393/803DF3B70200/H323/cch323_h225_send_release: Cause = 21; Location =0
Apr 21 23:11:44.679: //1393/803DF3B70200/H323/cch323_h225_send_release: h225TerminateRequest: src address = 169219585; dest address = 10.1.1.11
Apr 21 23:11:44.679: //1393/803DF3B70200/H323/cch323_h225_set_new_state: Changing from H225_SETUP state to H225_IDLE state
Try to add an incoming dial-peer like this:
dial-peer voice 1 voip
codec g711ulaw
incoming called-number .
no vad
If issue remain, post the output of "debug voice ccapi inout".
Regards.
Thanks for the post.
I have tried adding the incoming dial-peer, but I cannot add "sip-notify" unless I change the session protocol to sip, which it's not...
Here is what the debug show's:
Apr 23 16:23:25.660: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type SETUPIND
_CHOSEN
Apr 23 16:23:25.660: //1458/00023C020700/H323/setup_ind: callingNumber[5555551111] calledNumber
[15555551234]
Apr 23 16:23:25.660: //1458/00023C020700/H323/setup_ind: ---- calling IE present
Apr 23 16:23:25.660: //1458/00023C020700/H323/setup_ind: ====== PI = 0
Apr 23 16:23:25.660: //1458/00023C020700/H323/setup_ind: Receive: infoXCap 0
Apr 23 16:23:25.660: //1458/00023C020700/H323/setup_ind: Receive: infoXCap ccb 0
Apr 23 16:23:25.660: //1458/00023C020700/H323/setup_ind: Call Manager detected
Apr 23 16:23:25.660: //1458/00023C020700/H323/cch323_h225_receiver: SETUPIND_CHOSEN: src addres
Apr 23 16:23:25.660: //1458/00023C020700/H323/run_h225_sm: Received event H225_EV_SETUP_IND whi
Apr 23 16:23:25.660: //1458/00023C020700/H323/common_idle_setupInd_hdlr: full match is found
Apr 23 16:23:25.660: //1458/00023C020700/H323/cch323_h225_set_new_state: Changing from H225_IDL
Apr 23 16:23:25.660: //1458/00023C020700/H323/cch323_create_incoming_callinfo_block: peer 47204
B94, voice_peer_tag 1, ccb: 4C99EBE0
Apr 23 16:23:25.660: //1458/00023C020700/H323/cch323_create_incoming_callinfo_block: Calling Pa
rty is CCM
Apr 23 16:23:25.660: //-1/00023C020700/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Dan
   ----- ccCallInfo IE subfields -----
   cisco-ani=5555551111
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=15555551234
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Apr 23 16:23:25.664: //-1/00023C020700/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4929FD24, Call Info(
   Calling Number=5555551111,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed,
Presentation=Allowed),
   Called Number=15555551234(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=145
8
Apr 23 16:23:25.664: //-1/00023C020700/CCAPI/ccCheckClipClir:
   In: Calling Number=5555551111(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation
=Allowed)
   Out: Calling Number=5555551111(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentatio
n=Allowed)
Apr 23 16:23:25.664: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Apr 23 16:23:25.664: :cc_get_feature_vsa malloc success
Apr 23 16:23:25.664:  cc_get_feature_vsa count is 1
Apr 23 16:23:25.664: :FEATURE_VSA attributes are: feature_name:0,feature_time:1205074544,featur
e_id:107
Apr 23 16:23:25.664: //1458/00023C020700/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=5555551111(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presen
tation=Allowed),
   Called Number=15555551234(TON=Unknown, NPI=Unknown))
Apr 23 16:23:25.664: //1458/00023C020700/H323/cch323_h225_handle_deferred_ind: UnBuffering defe
rred indications
Apr 23 16:23:25.668: //1458/00023C020700/CCAPI/cc_process_call_setup_ind:
   Event=0x4956CBD0
Apr 23 16:23:25.668: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 15555551234
Apr 23 16:23:25.668: //1458/00023C020700/CCAPI/ccCallSetContext:
   Context=0x47D584C0
   >>>>CCAPI handed cid 1458 with tag 1 to app "_ManagedAppProcess_TOLLFRAUD_APP"
Apr 23 16:23:25.668: //1458/00023C020700/CCAPI/ccCallDisconnect:
   Cause Value=21, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=21, Call Entry(Responsed=TRUE, Cause Value=21)
Apr 23 16:23:25.668: //1458/00023C020700/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Apr 23 16:23:25.672: //1458/00023C020700/H323/run_h225_sm: Received event H225_EV_RELEASE while
at state H225_SETUP
Apr 23 16:23:25.672: //1458/00023C020700/H323/cch323_h225_send_release: Cause = 21; Location =
Apr 23 16:23:25.672: //1458/00023C020700/H323/cch323_h225_send_release: h225TerminateRequest: s
Apr 23 16:23:25.672: //1458/00023C020700/H323/cch323_h225_set_new_state: Changing from H225_SET
Apr 23 16:23:25.676: //1458/00023C020700/CCAPI/cc_api_call_disconnect_done:
2811voice#Disposition=0, Interface=0x4929FD24, Tag=0x0, Call Id=1458,
   Call Entry(Disconnect Cause=21, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Apr 23 16:23:25.676: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Apr 23 16:23:25.676: :cc_free_feature_vsa freeing 47D3FA68
Apr 23 16:23:25.676:  vsacount in free is 0
Dan.
Ok, I have figured it out.  Saw this in the debug:
Found out that there is a feature in 15.1 that prevents toll fraud.
I had to do this:
voice service voip
    ip address trusted list
     ipv4  []
And then the CM was a trusted source to push the call through the router.
Thanks.
Dan.
Had the same problem today, thanks for the answer.
Just to add to this if you have dial-peers configured with session target, calls from           those IPs will be accepted even if there is no trusted list configured.
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/112083-tollfraud-ios.html
