unable to call b/w local and outside movi users
rashmi.kumari
Hi Everyone,
we are using VCS starter pack as expressway with version X7.0.1 and vcs control with version X6.0
i have registered all movi users on vcs starter pack as expressway and able to login movi from outside
but unable to call between local registered end points  on vcs control and movi users registered on vcs satarter pack as expressway
done all the configuration on vcs starter and vcs control such as
1)created traversal zone on both vcs
2)created search rule to route call via traversal zone
please suggest what could be the problem
Hi Rashmi,
Can you check the VCS where the Ex60 registered. Go under status can call history.
check for the call  and from there can you provide the search history for the call. then we can atleast get a idea where to go furhter.
Alok
15 Replies 15
Michael Boscia
Level 4
Level 4
A couple questions to get you started:
  1. Do you have a maintenance contract?
    1. If so, are you able to execute a VCS sofware upgrade to get both devices on the same version of code?
  2. What do the logs say when you try to make a call between what appear to be internal (VCS-C) and external (VCS-E) users
    1. are you dialing/calling with the complete URI?
  3. Do calls fail in both directions?
    1. Specifically are you unable to make calls from both inside to outside, nor outside to inside?
Hi Michael,
Thanks for the reply.
now   1) i have made both the system on same version
vcs starter pack verX6.0 and vcs control X6.0
2)I can do calling internal to internal registered end points
3)movi users registered on vcs starter pack as expressway can call outside registered movi users
4)but unable to make call inside to outside and outside to inside
5)I am trying to call outside movi user with internal registered ex60 endpoint but showing contact is offline and can not call
logs showing call rejected
Hi Rashmi,
Alok
Hi Alok,
after checking the status under vcs control it showing
call summary
bandwidth
route:            default subzone->defaultsz totraversal sz->traversal subzone->zone001 to traversalSz->traversal zone
incoming call
source alias    rashmi@cups.amtek.com
target alias      manish1@cups.amtek.com
protocol           SIP
ip address       192.x.x
transport          TLS
reason             not found
cause                404
outgoing call
source alias    same
target alias     same
protocol        SIP
ip address      61.8.x.x
tranport         TCP
encryption     none
Hi All,
I am still not able to call between local registered endpoints and outside movi users.
Please suggests
Hi Rashmi,
From the search details it seem the VCS sends a request to traversal zone which is correct if you are calling to a outside MOVI user which is registered on VCS-Expressway.
Is the manish1@cups.amtek.com MOVI user registered on VCS-expressway. If yes, do you have proper search rules for calling to local zone on VCS-expressway.
Alok
HI Alok,
manish1@cups.amtek.com is the SIP URI of EX60 which is a local endpoint registered on vcs control and rashmi@cups.amtek.com is a movi user registered on vcs expressway
attached the various search rules created on vcs control and expressway
Hi Rashmi,
Why you have all the search rules on VCS-control set with priority as 100?
The search rules destined towards the traversal zone, i would recommend to set priority as 150, both for ip-address dialing and alias dialing to traversal zone.
After that test again.
While replying back please mention the call flow and also attach the search details for same call from both the expressway and control side
Alok
Hi Alok ,
I have set the priority to 150 on both serach rules
here attached the log history from both express and control
Hi Rashmi,
With this details it makes sense now. It seems call reached to VCS-expressway.
Also if you check the search rule on VCS-Expressway for local zone match..you see the target zone has kept to "traversal zone" which should be "local zone".
Please make the changes and test the call again.
Alok
Hi Alok,
now i am able to call local registered endpoint (manish1@cups.amtek.com) from outside movi user (rashmi@cups.amtek.com )but when i am calling outside movi user(rashmi@cups.amtek.com) from ex60(manish1@cups.amtek.com),its showing product not found.
here is the attached logs
Rashmi,
Have you made the changes i pointed previously. From the expressway search history it seems it is not able to find any of the URI's mentioned under the Findme id.
How exactly this 3 endpoint's mentioned under your find me id registered.. are all SIP or H.323?
What is the regitration type of Manish endpoint? is it a SIP or H.323
Alok
Alok,
all endpoints are SIP
Hi Rashmi,
In that case first test is try to dial the devices registered with your find me account directly and see are you able to dial them or not.
If you not then still there are problems with the search rules. If yes, then probably some configuration we are missing it out.
Also what i think is the device registered as manish1@cups.amtek.com on vcs-control is a H.323 endpoint.?
Alok
