11-20-2012 08:18 AM - edited 03-18-2019 12:10 AM
What is the process of upgrading TMS that is currently using TMSPE? I know with TMS Agent Legacy, you had to diable replication with any VCSs, but I'm not familiar with TMSPE as of yet, and how to upgrade TMS.
Solved! Go to Solution.
11-20-2012 09:02 AM
Just upgrade the tms regulary according to documentation. No need to disable polling.
/Magnus
11-20-2012 09:02 AM
The answer: searching in the forum is always a good start :-)
Check out Maheshs answer and Dales repsonse: https://supportforums.cisco.com/message/3688608#3688608
Good success!
11-20-2012 09:02 AM
/Magnus
11-20-2012 09:02 AM
Good success!
