Walkthrough Wednesdays
159
[URGENT]Problem DTMF Pin
Hi people,
I have a big problem here and I don't know where I start to solve this issue.
Topology:
Company A has 2 building and 1 VCS that works for both building.
Company B has 1 building, 1 VCS, 1 TP Server and 1 MCU Codian
Both VCS are connected through a SIP Trunk
The problem:
The communication works correctly point to point from the two building from "Company A" to "Company B", everything works correctly.
When we perform a call to the TP Server / MCU from building A (company A) to Company B everything works well. No problems here.
However, when we performed a call to the TP Server / MCU from the building B (company A) to  company B, the DTMF is not sent, if we create a room with PIN for example, it is not possible to connect the TP Server / MCU, because the company B does not receive the digits.
POINT TO POINT
Building A --> Company B = OK
Building B --> Company B = OK
Muilt Point
Building B --> Company B = The DTMF wasn't send
The building A have the same equipment, but TC 5.x and in the building B is TC 6.x
Can any one help me?
1 REPLY 1
Wayne DeNardi
VIP Advisor
To see whether it's a TC software issue - have you tried a TC5/6 endpoint in the other location from where it works?  Ie, try a TC6 in Building A and/or a TC5 in Building B.
In any case, I'd recommend you upgrading the TC5 (and TC6 if they're less than TC6.1) due to the multiple vulnerabilities in the software: Cisco-SA-20130619-TPC.
And even more so, to version TC5.1.11, TC6.2.1 or TC7.1.1 to address the OpenSSL Heartbleed issue.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Content for Community-Ad
Spotlight Awards 2021
