05-20-2016 01:46 PM - edited 03-18-2019 05:57 AM
Are there any codecs which come with a video out and a webcam video out? If not, what would I need to utilize my codec camera as a webcam? I need to sometimes initiate web conferencing calls in my VTC suite. I would like to integrate my VTC camera, microphones in and audio out in my codec into a computer workstation.
I would like to do this with an SX80 / MX700.
05-23-2016 10:22 AM
It's not possible to use any Cisco endpoint as a computer webcam, at least not out of the box. You could possible make something work with some audio/video devices connected to the codec to send the audio/video to the computer, but you might also need something at the computer to accept those inputs. In the end, you'd have to invest in third-party devices and spend some time with trial and error, probably too much work and time if you ask me as the endpoints weren't designed to do this.
05-23-2016 07:14 PM
Not directly. Simple answer to how we manage it we split the video signal from the cameras and feed them in a capture card on the PC you may need some virtual web cam software depending on which web conferencing software you use. We do the same with the audio signal. Generally in these room we are not using cisco cameras or microphones and are running a separate control system, basic the sx80 is added on to existing AV system with cameras and microphones. Pretty much unless it is a large room you are trying to set up just use a dedicated USB camera and microphone it will be a lot cheaper.
Some web conferencing systems let you dial in via Sip video calls including Webex, which is a lot easier.
05-23-2016 08:40 PM
As mentioned by the others in this thread, no, this is not possible with most standard computer workstations out of the box.
As others have mentioned, it's possible to add additional equipment to both the PC and the cameras to make this happen, but the cost of this would far exceed the cost of a dedicated web camera for your device.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
05-24-2016 08:28 AM
We did it to leverage the camera HD quality with a very famous client PC software. We used an Extron MediaPort 200 which converts an HDMI input from the codec, into USB to the computer. We had to figure out very specifically the configuration of the codec to make it work in both mode : videoconference (standard mode) and PC Peripheral. The codec is managed but an AMX Touch to provide any changes in the configuration.
As the others said, it is not a standard solution. It is a "home-made" solution for a specific customer.
I let you give it a go if you think you can get a kind of MediaPort 200.
Have Fun,
Cecile
04-07-2018 04:00 PM
04-20-2018 08:20 PM
The dual camera setup (Speaker Track) uses special technology in the codec to make that all work.
You could connect the display output of the codec to your camera input setup and enable self view with Speaker Track enabled. It's the work around of the century but could work...
Are you trying to use a GoToMeeting, Skype or something that doesn't support a video codec SIP or H323 Dial in?
04-29-2018 08:24 AM
I'm using videoconferencing web applications and clients, such as the department of defense DCS, and also Skype, etc. I don't believe I can connect via SIP.
I thought possibly I could connect one camera to a media bridge and turn off tracking. I haven't tried it yet.
I an also considering a Cisco Spark Room Kit Plus purchase and wondering if I'll be able to route the camera to a matrix and then back to the codec and media bridge.
12-10-2020 09:01 AM
Hi Cecile,
I am wondering about the specific configurations inside the codec in order to get the AEC to work. I have connected the REF of the Mediaport to a Line In on the Cisco codec, but I still get echo. Are you able to clarify at all about this?
05-01-2018 09:59 AM
05-01-2018 11:39 AM
Thanks, but I don't want to lose the speakertrack capability when I go back to H.323.
06-04-2019 05:57 PM
The answer is now "YES". Your option is the Room Kit mini which does have a USB out you can leverage for anything on your PC a typical USB web cam would be used for.
06-05-2019 02:25 AM
06-03-2021 02:22 AM
Yes, true. And, it's one or the other with the mini, there's no way to conduct two different transports simultaneously, but that is, now, a solution to my original question.
08-06-2021 06:33 AM - edited 08-06-2021 06:34 AM
i have also a SX10 and want to use them on Mac like a Webcam, but there is no easy way to use them.
With the USB i can´t get a connection?
