Walkthrough Wednesdays
293
Ahmed Abd El-Baky
Contributor
Using Screen License with CMR Premises 6 Solution
I purchased late last year Unified Workspace pro & Upgraded it to Multi Party Advanced to operate my Cisco Conferencing Solution , but now When the Cisco Virtual TelePresence server license is managed & operated by the Conductor . Conductor can only accept PMP & SMP .
Cisco Licensing team informed me that i can't upgrade my Screen license to Shared Multi Party (SMP) because they we not directly purchased . Is there any way to use those screen license with the current solution
My Current Versions are:
CUCM :11
vTS : 4.2
Conductor : X4.1
TMS : 15.1
Ahmed
1 ACCEPTED SOLUTION
Hi Ahmed,
This is true you can not use both licensing modes at the same time, it is a global conductor setting.  Do you already have PMP/SMP licenses on Conductor you are using?  If this is the case then you would most likely want to look at SL conversion of the PMP Advanced/Basic Screen Licenses.   After conversion those Screen Licenses would still exist on the Telepresence Server but PMP/SMP would take precedence and they would not be used while the TPS is in PMP/SMP mode.
-Jonathan
4 REPLIES 4
Jonathan Robb
Hi Ahmed,
PMP/SMP licensing is a configurable mode of Conductor, if your vTPS already has Screen Licenses you can configure Conductor to use the traditional Screen License configuration instead.
I am not sure of your purchasing route but there is a conversion method, I would advise speaking with your partner/vendor about this (CUWL-PMP-K9 will convert PMP basic/advanced to the new multiparty licensing, requires an A2Q process).
-Jonathan
Hi Jonathan ,
Thanks for the update , but i don't think i can have both licensing modes at the Conductors at the same time . If i disabled the Multiparty licensing on the Conductor ,  can i still have the PMP license on the Conductor for CMR & the screen license on the TS for video Endpoints ?
Many Thanks
Ahmed
Hi Ahmed,
-Jonathan
Many Thanks Jonathan
Content for Community-Ad
Spotlight Awards 2021
