09-05-2011 03:46 PM - edited 03-17-2019 10:28 PM
I was checking the VC devices installed in my network due to calls were drop unexpectedly.
Verifing the VCS, it is reporting "500 / Routed call has been inactive too long" message.
I have that see that message when the endpoint is inactive for a long time, but this is not the case, due to users are tryng to join a conference already in use.
I thank any comments about this issue...
greetings....
09-07-2011 02:11 AM
Check the involved firewall, often its a pretty fast TCP connection timeout or an application layer gw.
Also check your search rules and the signalling/call flow.
06-05-2012 07:39 PM
Martin,
I have the same issue for audio calls from a CUCM cluster.
I have not done too much debugging, but looking at the call history in the VCS x7.1, I see the video participants stayed in the call, but the audio participants got dropped with the error
After either 30 minutes and 41 seconds or 30 minutes and 42 seconds. By looking at the logs, it seems consistent.
Call information | |
State | Disconnected |
Start time | 2012-06-01 13:20:51 |
Duration | 30 minutes 42 seconds |
Tag | 48682d16-ac27-11e1-ba28-0010f31e2a10 |
Bandwidth | |
Requested | 768 kbps |
Allocated | 4000 kbps |
Route | nz_cucm-medctr01 -> nz_dgsom_vcsc |
Incoming call setup parameters | |
Source alias 1 | sip:NPANPX6556@10.86.1.11 (Url) |
Target alias 1 | sip:NPANPX6861@10.160.2.17:5060 (Url) |
Protocol | SIP |
Address | 10.86.1.11:5060 |
Transport | TCP |
Encryption type | None |
Reason | Routed call has been inactive too long |
Cause | 500 |
Outgoing call setup parameters | |
Target alias 1 | sip:NPANPX6861@10.160.2.17 (Url) |
Protocol | SIP |
Address | 10.164.0.16:5061 |
Transport | TLS |
Cause | 500 |
06-06-2012 05:47 AM
John,
"Routed call has been inactive too long" could indicate a problem with SIP session refreshes/re-INVITES/UPDATE failing.
To troubleshoot this however, we would need to get a diagnostics log from the VCS (as well as the xconf/xstat output of the VCS) you are seeing this error on.
The diagnostics log should have the 'Network log level' set to DEBUG and you should start logging before placing the test call. Once the test call drops, you can stop logging and raise a TAC case where you provide us with the log.
Increase the SIP refresh interval timers on the VCS Configuration > Protocols > SIP > Configuration page of the VCS could help in making the calls stay up longer, but is not likely to work as a permanent fix.
- Andreas
10-18-2012 07:00 AM
I see, that this is a quite old issue but I've just encountered possibly a variant of this error. I've got the following components: VCS 7.1, 4505 4.3(2.30), CUCM 8.6, CTS1000 1.9.1. A permanent conference is registered with a SIP URI on the VCS. Dialing out from the MCU to the CTS works properly. But when I'm trying to dial in from the CTS system to the MCU the call is dropped on the MCU with timeout, the CTS displays that the 'number is not reachable' on the screen and the VCS show the call connected. It stays connected for 30 minutes than it's dropped with '500 / Routed call has been inactive too long'. Is there any news on this issue?
P.
10-18-2012 11:42 AM
Peter,
Here is how we solved the problem.
MTP Setting on - set on the Call Manager solved it, with SIP Trunk between CM and VCS
Hope it helps.
10-18-2012 03:02 PM
I would be careful with MTP regards video towards the VCS, this can break more then it helps.
Any firewall in the path, especially something with ALG, L3-Inspection, ...
DNS records and ips all correct set, any strange transforms / search rules?
Config checked again towards the deployment guides?
These are things which tend to break a setup.
10-19-2012 01:20 AM
There is no firewall, and config is set according to deployment guides. I can dial into a C codec registered on the VCS without problems. I tried switching on the MTP on the trunk, but it did not help. I can dial the CTS from the MCU too.
10-19-2012 06:03 AM
Ok, this seems to be related to bug CSCty07061. Although what is strange, that if I'm calling an endpoint without the workaround applied for that bug, than the call is dropped on the VCS with 'Request terminated' while if I'm calling a conference in the MCU than the call gets stuck on the VCS.
