VCSE or EXP-E External Communication with F5 Load Balancer
Can we have F5 load balancer placed after Expressway-E external interface, and enable the internal and external communication through F5. F5 Load Balancer will have a NAT public IP address configured. Can we configure the same F5 public IP address as Expressway-E NAT Address.
is this solution workable and does Cisco support the same.
Thanks & Regards,
Nikhil Jayan
Jonathan Robb
Hi Nikhil,
Short answer would be negative, Expressway-E / VCS-Expressway would require a true 1 to 1 NAT for each Expressway.
-Jonathan
Patrick Sparkman
Looking through the deployment guides, it didn't mention the possible use of a NLB in the configuration.  However I did fine one item in bug search, CSCuc09457 that hopefully it might help.
