298
Dean O'Meara
Beginner
Video / Audio Issues - CTS1300
Hoping someone may have come across this issue before.
Customer has;
CTS: CTS 1.10.13(5) P1.
Conductor: XC3.0
TP Server: 4.1(1.79)
When the customer is using own kit they do not experience issues with Video / Audio however when they use our kit the call connects but receives no video / audio.
We have checked firewalls and nothing is being blocked, the logs on our TPS says it is a TIP/MUX negotiation failure.
I suspect this may have something to do with the version of conductor and TP Server we have as we are running a newer release and this could be causing the issue with the old CTS 1300 system.
Our versions;
Conductor: XC4.2
TP Server: 4.3(1.13)
I have had a look online to try compatibility matrix tables or anything that may tell me it is or isn't support but not found anything.
Has anyone experienced an issue similar to this?
2 REPLIES 2
Patrick McCarthy
I suspect your problem is simply the version of code on the 1300. That version almost certainly predates Cisco acquisition of Tandberg six years ago and as a result is not going to be compatible with the TPS, which came from Tandberg.  Upgrade the software on the 1300 and you will most likely solve the problem.
EDIT - confirmed - you need at least 1.6 to work with the TPS. Cisco doesn't even post anything older than 1.9 - you need to upgrade that unit.
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/ts/admin_guide/Cisco-TelePresence-Server-Printable-Help-4-3-Virtual-Machine.pdf
Thanks for the reply Patrick.
We have managed to fix this by changing some settings within CUCM and also applying a quality template on the conductor.
Create
Recognize Your Peers
Content for Community-Ad
