voice volume is low when analog line connected to FXO port (2911)
nareh84
Level 3
Level 3
hi,
when i connect analog line direct to analog phone the voice volume is fine but when i connect to 2911 router (fxo port) the volume is low. i have cucmbe8.6 as call agent and 2911 as voice gateway.. following is the config for voice ports
voice-port 0/1/0
translation-profile incoming from-PSTN
supervisory disconnect dualtone mid-call
input gain 14
compand-type a-law
cptone OM
timeouts call-disconnect 5
timeouts wait-release 5
connection plar opx 111
caller-id enable
voice-port 0/1/1
input gain 14
compand-type a-law
cptone OM
caller-id enable
paolo bevilacqua
Raise volume on IP phone.
hehe.. the volume on 8941 is maximum..any command that i am missin?
You can try a THL tone-sweep test (search) to optimize line impedence.
Other than that, use digital circuits not analog.
