05-04-2017 12:57 AM - edited 03-18-2019 01:04 PM
Hi Everyone,
we have a SX20 Endpoint which we want to use for Webex meetings.
The device is only connected via the internet.
Is it possible to have Webex meetings with this device or do we need something like TMS or VCS?
Solved! Go to Solution.
05-04-2017 02:05 PM
If you have H323 capable endpoints, you should be able to dial into a CMR Cloud meeting. Take a look at Cisco WebEx Meeting Center Video Conferencing Enterprise Deployment Guide (WBS31) for more information.
05-04-2017 02:55 AM
Are you referring to Hybrid CMR or CMR cloud ? If its cloud CMR then you can join but for hybrid CMR you need on premises infra to join in webex.
Alok
05-04-2017 02:58 AM
If we have CMR Cloud we can setup and join Webex meetings without any extra infrastructure, is this correct?
Kind regards,
Jordy
05-04-2017 02:05 PM
05-04-2017 08:21 PM
As Patrick Sparkman indicates, a H323 capable video endpoint can dial to WebEx.
Cisco SX20 endpoints when configured as standalone endpoint, should be able to dial WebEx without problems, as the cloud supports H323. I think that the only condition is to dial using a SIP URI format, nnnn@domain.com, which requires the SX20 to have DNS configured, to be able to resolve the domain to an IP address.
05-04-2017 10:47 PM
Thanks a lot for the feedback!
