694
Highlighted
Beginner
Webex Room Kit Plus poor video when Speaker Track ON
Greetings, we have a few WebEx room kit plus systems running version RoomOS 2018-07-12 9f2c038ae6 and when Speaker Track is set to On, and the camera zooms/ follows the speaker, the picture is far from HD quality.  If I disable Speaker Track then the image quality is beautiful.  Would this be a bug in the software or is that a limitation of the Speaker track feature?  Many thanks!
2 REPLIES 2
Highlighted
That should be a SW bug. The camera is, if memory serves, 4K so it can still transmit HD when doing Best Overview or SpeakerTrack. Open a case and put pressure on them to troubleshoot it in the current build instead of stalling in hopes the next build fixes it.
Highlighted
VIP Advisor
It could be a motion/quality tradeoff if there is not enough bandwidth available.   Higher motion / FPS on the same bandwidth will be a lower resolution than less motion at a higher resolution.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Content for Community-Ad
