12-06-2019 03:29 PM
We have a Webex Room Kit Plus, we use 4 screen displays, those screens should wake up when the Room Kit is turned on but it seems to be impossible with the four screens (It works with two screens).
It's there a third party accesory or Cisco which we could use?
Cheers,
12-23-2019 04:53 PM
It will depend on how you have all the screens connected and whether the infrastructure you are using to connect them all is capable of receiving and passing on the HDMI CEC signals to be able to turn the displays on and off.
Please remember to mark helpful responses and to set your question as answered if appropriate.
12-27-2019 02:12 PM
Hi Christian,
Make sure all the settings are the same on the display devices. I have run into this issue multiple times where a power setting on the TV itself doesn't allow Cisco's CEC control to wake up the TVs. (This is assuming all these TVs are the same model connected to the same codec.)
