Webex Roomkit Pro with Quad Camera and P60 Camera
paulonwude
Can I setup the Room Kit Pro with a Quad camera and a P60 Camera at the same time?
Plus what will the user experience at the far end be like?
--Paul
davisjaron
Hi Paul,
Yes you can!  With the Webex Room Kit Pro you can absolutely hook up both the quad cam and the P60 at the same time.  Ethernet 2 and 3 serve as Camera Control ports and HDMI IN 1 and 2 serve as your HDMI inputs for the Cameras.  Correlate the control ports and hdmi inputs to match up.
The far end user experience depends on the device they have and what is selected on the room system with both camera's, but generally speaking you will only send one camera feed and/or one presentation at a time.
Refer to the administrator guide for more information: https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/ce95/codec-pro-administrator-guide-ce95.pdf
davisjaron
Hi Paul,
Many thanks
Hello Davis,
What about the audio?  I will continue use the mic array of the quad camera?
Thanks in advance,
Manuel
