05-06-2021 08:30 AM
For Webex's meeting participants, would the participant's profile pic require the same bandwidth requirements if the participate used a video? Why or Why not? I am trying to understand if the bandwidth is really reduced if participants turn off video, but still has a profile pic that may require bandwidth. Is there a significant difference in bandwidth requirements?
Solved! Go to Solution.
05-06-2021 09:44 AM - edited 05-06-2021 09:48 AM
Yes, there is significant difference in bandwidth requirement when video is turned ON and OFF. Each active thumbnail (profile picture) takes approximately 60-100 kb/s of bandwidth. If participant turns on video, depending on resolution it requires more bandwidth.
Layer |
Bandwidth Range |
90p active thumbnail (each) |
~60-100 kb/s |
180p main video |
125-200 kb/s |
360p main video |
470-640 kb/s |
720p main video |
900k-1.5 mb/s |
Content sharing (sharpness, 1080p/5) |
120k – 1.3 mb/s |
Content sharing (motion, 720p/30) |
900k – 2.5 mb/s |
Please refer to below white paper which has more details. Specifically refer to Table 1, 2, 3 and 4 which will provide more details to your question.
05-06-2021 09:57 AM
I understand. Thanks for the response.
05-06-2021 03:34 PM - edited 05-06-2021 03:38 PM
The profile pic is a static image it’s not using as much bandwidth vs a live video call, if that’s what you’re asking. You may be able to see this in help menu and see your audio and video stats https://help.webex.com/en-us/nmghd9e/Check-the-Audio-and-Video-Statistics-of-Your-Cisco-Webex-Meeting When sending video vs not sending video. Turning off video will display their profile picture or avatar and will save bandwidth allowing for audio only as an option.
05-06-2021 03:38 PM
Good point. Thanks.
05-06-2021 09:57 AM
Layer |
Bandwidth Range |
~60-100 kb/s |
180p main video |
125-200 kb/s |
360p main video |
470-640 kb/s |
720p main video |
900k-1.5 mb/s |
120k – 1.3 mb/s |
900k – 2.5 mb/s |
Welcome to the Webex Community. This is your home to ask questions, share knowledge, and attend live webinars.
