Walkthrough Wednesdays
5334
James Wood
Beginner
Webex Teams Hybrid Calls not working to outbound numbers (Urgent)
Our hardware VM died and we rehosted our VMs on a new ESXI server.
Everything working great including inbound but I can't get calling PSTN numbers from the Webex Teams app to work.
We exported and imported the guest VMs (CUCM, Exp C and E) so no settings have changed.
When we make a PSTN call from Webex Teams the call doesn't connect and Exp E is showing 404 not found on the final leg. It appears to be trying the Default Zone instead of matching the ciscospark.com search rule so it never reaches my VCS-C server. I think that is wrong?
Call flow: Dialled 0800800150 from my Webex Teams app.
cucmpub.abcd.com is my CUCM server.
james@mycompany.call.ciscospark.com is my Webex Teams URI.
Search history below:
Search (41)
State: Completed
Found: False
Reason: Not found
Type: SIP (INVITE)
SIPVariant: Standards-based
CallSerial Number: 9d09ffea-a894-494b-ad8d-747fe195e6ec
Tag: 699ee272-e8ba-42ef-8bd9-ae80f7831d52
Source (1)
Authenticated: True
Aliases (1)
Alias (1)
Type: Url
Origin: Unknown
Value: james@mycompany.call.ciscospark.com
Zone (1)
Type: DNS
Path (1)
Hop (1)
Address: l2sip-cfa-02.wbx2.com:5062
Hop (2)
Address: 127.0.0.1:5070
Destination (1)
Alias (1)
Type: Url
Origin: Unknown
Value: sip:0800800150@cucmpub.abcd.com;user=phone
StartTime: 2019-03-17 11:46:54
Duration: 0.06
SubSearch (1)
Type: Directed
Path (1)
Hop (1)
Address: 62.252.x.x
Hop (2)
Address: cucmpub.abcd.com
SubSearch (1)
Type: Admin Policy
Action: Proxy
ResultAlias (1)
Type: H323Id
Origin: Unknown
Value: sip:0800800150@cucmpub.abcd.com;user=phone;box-call-serial-number=c18a65df-42d0-4990-a97b-05fb59c18ab8
Zone (1)
Type: Default
Protocol: SIP
Found: False
Reason: Not found
Duration: 0.06
Gatekeeper (1)
Address: 172.16.31.251:5071
Alias (1)
Type: H323Id
Origin: Unknown
Is the 404 coming from itself, VCS C or CUCM?
Call Details
Call information
State Connection Failed
Start time 2019-03-17 11:46:54
End time 2019-03-17 11:46:54
Duration 0 seconds
Tag 699ee272-e8ba-42ef-8bd9-ae80f7831d52
Serial number 9d09ffea-a894-494b-ad8d-747fe195e6ec
Type Video
SIP variant Standards-based
Bandwidth
Requested 16064 kbps
Allocated 16064 kbps
Route Spark_DNS -> Zone005ToTraversalSZ -> TraversalSubZone -> TraversalSZtoDefaultZ -> DefaultZone
Leg 1
Bandwidth node Spark_DNS
Source alias 1 sip:james@mycompany.call.ciscospark.com (Url)
Target alias 1 sip:0800800150@cucmpub.abcd.com;user=phone (Url)
Protocol SIP
Address 18.217.166.80:34681
Transport TLS
Reason Not found
Cause 404
Leg 2
Bandwidth node Default zone
Target alias 1 sip:0800800150@abcd.purplewifi.com;user=phone (Url)
Protocol SIP
Address 62.252.x.x:5062
Transport TLS
Leg 3
Protocol SIP
Address 172.16.31.251:5071
Transport TLS
Encryption type None
Session 1
Status Replaced
Media routed False
Call routed True
Participant 1 Leg 1
Participant 2 Leg 2
Bandwidth allocated 0 kbps
Bandwidth requested 0 kbps
Session 2
Status Failed
Media routed False
Call routed True
Participant 1 Leg 1
Participant 2 Leg 3
Bandwidth allocated 16064 kbps
Bandwidth requested 16064 kbps
Zones
DefaultZone Default zone 0 0 kbps Off On
B2B External DNS 0 0 kbps Off On Enabled search rules: 1
Spark_DNS DNS 0 0 kbps Off On Enabled search rules: 1
Spark_to_VCS-C Traversal server 0 0 kbps Off Active Enabled search rules: 1
Unified Traversal Unified Communications traversal 0 0 kbps Off Active Enabled search rules: 2; disabled search rules: 1
VCS-C Traversal Zone Traversal server 0 0 kbps Off Active No search rules configured
Webex Zone Webex 0 0 kbps Off On Enabled search rules: 1
Search Rules
49 Webex DNS SIP Any No Alias pattern match Regex (.*)@(.*)(\.webex\.com).* Replace Stop Webex Zone All SIP Variants
50 Incoming SIP Any No Alias pattern match Regex ^\S+@abcd.com Leave Stop Unified Traversal All SIP Variants
51 Incoming2 SIP Any No Alias pattern match Regex ^\S+@cucmpub.abcd.com Leave Stop Unified Traversal All SIP Variants
52 B2B External Any VCS-C Traversal Zone No Alias pattern match Regex ^\S+@\S+$ Leave Continue B2B External Any
100 From Spark Hybrid to Exp-C SIP Spark_DNS No Any alias Stop Spark_to_VCS-C All SIP Variants
100 From Unified CM to Spark Hybrid SIP Spark_to_VCS-C No Alias pattern match Regex .*@.*\.ciscospark\.com Leave Stop Spark_DNS All SIP Variants
102 LocalZoneMatch Any Any No Any alias Continue Unified Traversal Any
I really appreciate your help.
James
10 REPLIES 10
James Wood
Beginner
Really sorry to bump but I have until the morning before the office re-opens after the weekend and really looking for some community help.
James
We're having the exact same problem.  But we had it working, upgraded the Expressway and CUCM servers to the latest version then it stopped working.  No matter what I do, inbound calls from Webex and Webex Teams hit the default zone (search rule) instead of the hybrid inbound rule.  I have a case open with TAC but it's going on 4 days now and they have nothing.  I'll update this if we make any progress.
Hi, did you find a cause for this problem? I'm experiencing the same.
We did solve it, in our case it was due to the network setup as it was natting and thus sending the traffic to the wrong place. I fixed it my enabling the IPv4 static NAT mode on the System > Network > IP page. Set both of these:
IPv4 static NAT mode: On
IPv4 static NAT address: Your public IP
Thanks for the reply James. Unfortunately I already have that setting configured.
Any update on this? I am experiencing the same problem setting up hybrid calling for WebEx devices. All calls from Webex to the Expressway E are hitting the default zone instead of the WebEx Zone. Expressway 12.5.9
OK. I found out the problem with this for me. The Public SRV record for _sip._tcp.<domain> was pointing to 5061. once I updated the entry to 5062 the webex zone started catching the inbound. Hope this helps someone else.
Hi Nathan,
You should not be deploying WebEx hybrid calls today. You should be using one of the offerings with WebEx Teams...
1. Webex Teams ( CUCM calling mode)
2. WebEx Teams (Jabber Mode)
Both of these options will allow team client to register as a CSF device in cucm and will use your normal MRA discovery setup to locate your expressway.
Please rate all useful posts
Thanks for the reply. We are using teams with cucm calling mode but we needed a way to allow WebEx room devices in the cloud (e.g. room kits) to dial out using cucm services. Is there an alternative solution that I am missing?
For devices hybrid calling is still the process required to allow endpoints to be integrated. Only other option would be registering to CUCM still and then using edge for devices to make them cloud aware. Really depends on your needs. Also this doesn’t provide a personal device experience to cloud registered. Only really useful with Places
Content for Community-Ad
Spotlight Awards 2021
