03-17-2019 05:49 AM - edited 03-17-2019 12:04 PM
Our hardware VM died and we rehosted our VMs on a new ESXI server.
Everything working great including inbound but I can't get calling PSTN numbers from the Webex Teams app to work.
We exported and imported the guest VMs (CUCM, Exp C and E) so no settings have changed.
When we make a PSTN call from Webex Teams the call doesn't connect and Exp E is showing 404 not found on the final leg. It appears to be trying the Default Zone instead of matching the ciscospark.com search rule so it never reaches my VCS-C server. I think that is wrong?
Call flow: Dialled 0800800150 from my Webex Teams app.
cucmpub.abcd.com is my CUCM server.
james@mycompany.call.ciscospark.com is my Webex Teams URI.
Search history below:
Search (41) State: Completed Found: False Reason: Not found Type: SIP (INVITE) SIPVariant: Standards-based CallSerial Number: 9d09ffea-a894-494b-ad8d-747fe195e6ec Tag: 699ee272-e8ba-42ef-8bd9-ae80f7831d52 Source (1) Authenticated: True Aliases (1) Alias (1) Type: Url Origin: Unknown Value: james@mycompany.call.ciscospark.com Zone (1) Name: Spark_DNS Type: DNS Path (1) Hop (1) Address: l2sip-cfa-02.wbx2.com:5062 Hop (2) Address: 127.0.0.1:5070 Destination (1) Alias (1) Type: Url Origin: Unknown Value: sip:0800800150@cucmpub.abcd.com;user=phone StartTime: 2019-03-17 11:46:54 Duration: 0.06 SubSearch (1) Type: Directed Path (1) Hop (1) Address: 62.252.x.x Hop (2) Address: cucmpub.abcd.com SubSearch (1) Type: Admin Policy Action: Proxy ResultAlias (1) Type: H323Id Origin: Unknown Value: sip:0800800150@cucmpub.abcd.com;user=phone;box-call-serial-number=c18a65df-42d0-4990-a97b-05fb59c18ab8 Zone (1) Name: DefaultZone Type: Default Protocol: SIP Found: False Reason: Not found StartTime: 2019-03-17 11:46:54 Duration: 0.06 Gatekeeper (1) Address: 172.16.31.251:5071 Alias (1) Type: H323Id Origin: Unknown Value: sip:0800800150@cucmpub.abcd.com;user=phone;box-call-serial-number=c18a65df-42d0-4990-a97b-05fb59c18ab8
Is the 404 coming from itself, VCS C or CUCM?
Call Details
Call information | |
State | Connection Failed |
Start time | 2019-03-17 11:46:54 |
End time | 2019-03-17 11:46:54 |
Duration | 0 seconds |
Tag | 699ee272-e8ba-42ef-8bd9-ae80f7831d52 |
Serial number | 9d09ffea-a894-494b-ad8d-747fe195e6ec |
Type | Video |
SIP variant | Standards-based |
Bandwidth | |
Requested | 16064 kbps |
Allocated | 16064 kbps |
Route | Spark_DNS -> Zone005ToTraversalSZ -> TraversalSubZone -> TraversalSZtoDefaultZ -> DefaultZone |
Leg 1 | |
Bandwidth node | Spark_DNS |
Source alias 1 | sip:james@mycompany.call.ciscospark.com (Url) |
Target alias 1 | sip:0800800150@cucmpub.abcd.com;user=phone (Url) |
Protocol | SIP |
Address | 18.217.166.80:34681 |
Transport | TLS |
Reason | Not found |
Cause | 404 |
Leg 2 | |
Bandwidth node | Default zone |
Target alias 1 | sip:0800800150@abcd.purplewifi.com;user=phone (Url) |
Protocol | SIP |
Address | 62.252.x.x:5062 |
Transport | TLS |
Leg 3 | |
Protocol | SIP |
Address | 172.16.31.251:5071 |
Transport | TLS |
Encryption type | None |
Session 1 | |
Status | Replaced |
Media routed | False |
Call routed | True |
Participant 1 | Leg 1 |
Participant 2 | Leg 2 |
Bandwidth allocated | 0 kbps |
Bandwidth requested | 0 kbps |
Session 2 | |
Status | Failed |
Participant 2 | Leg 3 |
Bandwidth allocated | 16064 kbps |
Bandwidth requested | 16064 kbps |
Zones
03-17-2019 11:57 AM
03-18-2019 04:44 AM
We're having the exact same problem. But we had it working, upgraded the Expressway and CUCM servers to the latest version then it stopped working. No matter what I do, inbound calls from Webex and Webex Teams hit the default zone (search rule) instead of the hybrid inbound rule. I have a case open with TAC but it's going on 4 days now and they have nothing. I'll update this if we make any progress.
05-16-2019 04:26 PM
Hi, did you find a cause for this problem? I'm experiencing the same.
05-17-2019 12:08 AM
We did solve it, in our case it was due to the network setup as it was natting and thus sending the traffic to the wrong place. I fixed it my enabling the IPv4 static NAT mode on the System > Network > IP page. Set both of these:
