Walkthrough Wednesdays
657
What I need to do a Downgrade?
Hello.I have a Quick Set C20 with 5.1.1 FW version. I need to downgrade it to the 4.2.3 version.
Do I need a release key?
Thanks for your response!
2 ACCEPTED SOLUTIONS
Magnus Ohm
You need to have the release key for tc4.x yes.
/Magnus
Tomonori Taniguchi
For C-series software upgrade including Quick Set C20 required software and release key (as Magnus advise earlier).
You may use following methods for getting TC4.x release key for your C20 software upgrade (to TC4.2.3).
1) Contact Cisco License Team (license@cisco.com) with your Endpoint Serial Number and service contract information. Cisco License Team will reply you with necessary information.
2) Check license from on-line tool.
  • Go to http://www.cisco.com/go/license
  • Click on Get Existing.
  • From the drop down select Tandberg License.
  • Enter C20 serial number in “Serial Number:” field and keyword on following fields and then click Search.
  • Look for key starting “1TC00” and if you find key starting “1TC004-0-xxxxxxx” then you may use it for TC4.2.3 software upgrade.
  • If you see key starting other than 1TC004 (i.e. 1TC003, 1TC005) then that release key is for other TC software version so you will need contact Cisco License Team.
3 REPLIES 3
Magnus Ohm
/Magnus
Thanks you very much, Magnus.
Tomonori Taniguchi
Content for Community-Ad
Spotlight Awards 2021
