What is difference between TC5.1.4 and TCNC5.1.4?
Arbenjamin
Dear all,
In the Cisco Download page, we have found there are TC5.1.4 and TCNC5.1.4, we would like to know the meaning of TCNC?
Best Regards,
Ben
Dharmesh Nandoria
Hi Lai,
TC : software is with encryption- AES encryption
TCNC : software is w/o incryption .
Both software using diffrent release keys.
Kind regards,
Dharmmesh
6 Replies 6
Dharmesh Nandoria
Hi Lai,
Kind regards,
Dharmmesh
Hi Nandoria,
Thank for your support.
I have visited the Product License Registeration Page, there is only TC software key avalibale.
Would you mind telling more about on the usage on the TCNC : software is w/o incryption ?
Many Thanks,
Ben
It is illegal for Cisco (and the rest) to export software with encryption to some countries, hence the NC option.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Does using TCNC instead of TC have any instance on call quality or the way a call is handled?
Steve, no it does not. On TC software you can set the endpoint to not encrypt ever, force it on, or automatic (encrypt when it can, connect without it if it cannot). On TCNC it basically removes the last two modes, the endpoint does not support encryption. It does not affect call quality or routing at all.
Thank you for the quick reponse Patrick :-)
