09-25-2012 10:42 PM - edited 03-17-2019 11:52 PM
Dear all,
In the Cisco Download page, we have found there are TC5.1.4 and TCNC5.1.4, we would like to know the meaning of TCNC?
Best Regards,
Ben
Solved! Go to Solution.
09-25-2012 11:27 PM
Hi Lai,
TC : software is with encryption- AES encryption
TCNC : software is w/o incryption .
Both software using diffrent release keys.
Kind regards,
Dharmmesh
09-25-2012 11:27 PM
Hi Lai,
Kind regards,
Dharmmesh
09-25-2012 11:43 PM
Hi Nandoria,
Thank for your support.
I have visited the Product License Registeration Page, there is only TC software key avalibale.
Would you mind telling more about on the usage on the TCNC : software is w/o incryption ?
Many Thanks,
Ben
09-26-2012 01:30 AM
It is illegal for Cisco (and the rest) to export software with encryption to some countries, hence the NC option.
/jens
04-12-2016 04:59 AM
Does using TCNC instead of TC have any instance on call quality or the way a call is handled?
04-12-2016 06:57 AM
Steve, no it does not. On TC software you can set the endpoint to not encrypt ever, force it on, or automatic (encrypt when it can, connect without it if it cannot). On TCNC it basically removes the last two modes, the endpoint does not support encryption. It does not affect call quality or routing at all.
04-12-2016 07:02 AM
Thank you for the quick reponse Patrick :-)
