What kind of ISR do I need for a SBC for intercompany TP
marrachart
We've a TP environment met 14 single screen TP endpoints and would like to make an interconnect with another company to expend our reach.
What kind of ISR do I need to terminate the interconnect on (for address hiding) and how do you calculate what kind of ISR you need for this?
Many thanks.
Martijn
5 Replies 5
hdewulf
Herllo Martijn
Did you check the SRND doc on this URL :
http://www.cisco.com/en/US/docs/solutions/Enterprise/Video/TelePresence_Network_Systems_2.0_DG.pdf
This give some info on your open question.
Regards.
-Hans
Documents references to the Cisco XR12000 series routers but what is the lowest possible ISR which you can use and how does it scale up?
For instance, is a 2900 of 3900 series capable of doing the inter-company communication and how many sessions can it handle?
SBC via the Telepresence release notes is supported only for :
http://www.cisco.com/en/US/docs/telepresence/cts_admin/1_7/release/notes/cts_1_7_release_notes.html
Session Border Controller (SBC)
GSR-SBC 3.7.1
ASR-SBC 2.4.1
ASR-SBC 2.6.2
SBC software is only available for :
- SBC on ISR
- SBC on ASR
- SBC on GSR-IOX
- SBC on 7600
I run a CUBE IOS on a 3845 for TP intercompany and it works fine, but we've never run more than 2 x CTS-3000s accross it do I
don't know how well it will scale.  CPU usage isn't too high though.
It can handle   5 session of CTS 3000.
If the calls are CTS 1000, you could increase the call capacity to 5 * 3  = 15.
For CUBE IOS version :
