10-11-2017 05:22 AM - edited 03-18-2019 01:31 PM
Dear Colleagues,
I am looking for a supported solution for H323 communication between Edges. For security purposes the communication has to flow within the DMZs.
As I can see there are two ways to cover our requirements, I have collected the port requirements as well.
- Traversal server/client zone
Src: Customer's EXP Edge
Dst: Provider's EXP Edge
Port:
TCP 1720, 2776, 2777
UDP 1719, 2776, 2777, 6001, 36000-59899
- Neighbor zone
Port:
TCP 1720, 15000-19999
UDP 1719, 36000-59899
Src: Provider's EXP Edge
Dst: Customer's EXP Edge
Port:
Is there any restriction regarding the mentioned scenarios? I don't want to implement an unsupported solution.
Laszlo
Solved! Go to Solution.
10-11-2017 05:46 AM
Hi Laszlo,
Traversal zones are meant for communications between C and E.
Two E's (and even more so, two E's from different domains/companies etc) should be communicating across a neighbor zone.
Ports look ok.
Cheers,
Zoltán
10-11-2017 05:46 AM
Hi Laszlo,
Ports look ok.
Cheers,
Zoltán
10-11-2017 05:53 AM
Thank you Zoli!
