ysugimot
【Overview】
ASR1000 シリーズの詳細は下記ページに記載されています。
http://www.cisco.com/web/JP/product/hs/routers/asr1000/index.html
http://www.cisco.com/web/JP/product/hs/routers/asr1000/prodlit/iosxelic_pb.html
http://www.cisco.com/web/JP/product/hs/routers/asr1000/prodlit/data_sheet_c78-447652.html
http://www.cisco.com/web/JP/product/hs/routers/asr1000/prodlit/pdf/iosxelic_pb.pdf
http://www.cisco.com/en/US/docs/ios-xml/ios/csa/configuration/xe-3s/csa-cfg-sw-activation.html#GUID-1C45B079-F817-430A-8BD6-54F3480BE3F7
【型番】
ライセンスの型番は以下のものがあります。
FLSASR1-CUE-100
FLSASR1-CUE-500
FLSASR1-CUE-1K
FLSASR1-CUE-4K
FLSASR1-CUE-16K
FLSASR1-CUE-100=
FLSASR1-CUE-500=
FLSASR1-CUE-1K=
FLSASR1-CUE-4K=
FLSASR1-CUE-16K=
L-FLSASR1-CUE-100
L-FLSASR1-CUE-500
L-FLSASR1-CUE-1K
L-FLSASR1-CUE-4K
L-FLSASR1-CUE-16K
L-FLSASR1-CUE-100=
L-FLSASR1-CUE-500=
L-FLSASR1-CUE-1K=
L-FLSASR1-CUE-4K=
L-FLSASR1-CUE-16K=
L-AIS-AES-EVAL
L-ASR1001-5G-EVAL
FLASR1-CE-500R
FLASR1-CE-1KR
FLASR1-CE-4KR
FLASR1-CE-16KR
FLASR1-CE-100R=
FLASR1-CE-500R=
FLASR1-CE-1KR=
FLASR1-CE-4KR=
FLASR1-CE-16KR=
L-FLASR1-CE-100R=
L-FLASR1-CE-500R=
L-FLASR1-CE-1KR=
L-FLASR1-CE-4KR=
L-FLASR1-CE-16KR=
CSP-TPEX-RED
L-CSP-TPEX-RED=
CSP-TPEX-RED=
L-CSP-32KP-RED=
L-CSP-16KP-RED=
CSP-16KP-RED=
CSP-250P-RED=
CSP-16KP-RED
CSP-32KP-RED
CSP-2KP-RED=
CSP-4KP-RED=
CSP-4KP-RED
L-CSP-2KP-RED=
L-CSP-4KP-RED=
CSP-2KP-RED
L-CSP-250P-RED=
CSP-32KP-RED=
CSP-250P-RED
CSP-10KP-RED=
L-CSP-10KP-RED=
SLASR1-AIS=
L-SLASR1-AIS=
SLASR1-AES=
L-SLASR1-AES=
FLSASR1-IOSRED=
L-SLASR1-IPB-AES
SLASR1-IPB-AIS=
SLASR1-IPB=
FLSASR1-FPI
FLSASR1-BB
FLSASR1-CS-LAB
L-FLSASR1-CS-TPEX
L-FLSASR1-CS-32KP
L-FLSASR1-IOSRED=
L-FLSASR1-IOSRED
L-FLSASR1-CS-32KP=
L-FLSASR1-FW=
L-FLSASR1-CS-250P
L-FLSASR1-CS-16KP=
L-FLSASR1-FWNAT-R
FLSASR1-IPSEC
FLSASR1-BB-4K
L-FLSASR1-IPSEC
L-FLSASR1-CS-2KP
L-FLSASR1-FW
SLASR1-IPB-AES=
L-FLS-ASR1001-5G=
L-FLSASR1-FWNAT-R=
L-FLSASR1-FPI=
L-FLSASR1-BB=
SLFL-ASR1=
ASR1001_REHOST
SLASR1-AES
FLSASR1-FWNAT-R
FLS-ASR1001-5G
L-SLASR1-AIS-AES=
FLSASR1-BB-16K=
L-FLSASR1-BB-16K
SLASR1-AIS-AES=
L-FLSASR1-BB-32K
FLSASR1-CS-16KP=
FLSASR1-CS-250P=
FLS-ASR1001-5G=
FLSASR1-CS-LAB=
L-FLSASR1-CS-16KP
FLSASR1-FPI=
FLSASR1-CS-16KP
FLSASR1-CS-32KP
SLASR1-IPB
L-FLSASR1-BB-32K=
L-FLSASR1-BB-4K
FLSASR1-CS-2KP=
FLSASR1-BB-4K=
FLSASR1-CS-4KP=
L-FLSASR1-LI
L-FLS-ASR1001-5G
L-FLSASR1-CS-LAB
FLSASR1-FWNAT-R=
FLSASR1-IOSRED
FLSASR1-CS-4KP
L-FLSASR1-CS-4KP
L-SLASR1-IPB-AIS
L-SLASR1-IPB-AES=
L-FLSASR1-CS-2KP=
FLSASR1-FW=
FLSASR1-BB-32K=
L-FLSASR1-BB
L-SLASR1-IPB-AIS=
L-FLSASR1-CS-4KP=
FLSASR1-FW
FLSASR1-CS-2KP
SLASR1-AIS
FLSASR1-CS-TPEX
FLSASR1-BB-16K
ASR1_SHELL_ACCESS_1DAY
L-FLSASR1-CS-250P=
L-FLSASR1-CS-TPEX=
L-SLFL-ASR1=
L-FLSASR1-IPSEC=
L-FLSASR1-FPI
FLSASR1-BB=
L-SLASR1-AIS-AES
FLSASR1-LI
FLSASR1-CS-TPEX=
FLSASR1-IPSEC=
FLSASR1-LI=
FLSASR1-CS-32KP=
ASR1_MFGINSTALL
L-SLASR1-IPB=
L-FLSASR1-BB-16K=
L-FLSASR1-BB-4K=
L-FLSASR1-LI=
L-FLSASR1-CS-LAB=
FLSASR1-CS-250P
FLSASR1-BB-32K
【製品新規購入時】
- ライセンス状態
出荷される各デバイスには、ライセンスはインストールされていません。
追加ライセンスやアップグレードライセンスはPAKでの提供となります。
- ライセンス取得手順
*PAKにて提供されたライセンスの場合には 入手した
PAK コードと UDI を Cisco のオンライン ライセンス ポータル(http://www.cisco.com/go/license )に登録します。
必要情報:
PAK:
Product ID: *1
Serial#:*1
*1確認コマンド"show license udi"
【RMA時】
- ライセンス状態
RMAされた機器は、ライセンスは含みません。
- ライセンス取得手順
追加で購入したライセンス(Advanced IP Services など)を転送(リホスト)する場合は、
RMA ポータル(https://tools.cisco.com/SWIFT/Licensing/LicenseAdminServlet/getProducts )が用意されています。
必要情報:
故障機と代替機の下記情報
Product ID: *1
Serial#:*1
上記RMAポータルにて転送(リホスト)ができない場合には故障品/代替品のS/N、
代替品UDI, "Show Version"を添えて変更(リホスト)依頼をJapan TACまで申請してください。
- ライセンス投入手順
Please note the Unique Device Identifier (UDI) for this license. This license can only be installed on the router that has this matching UDI.
License installation example using CLI:
CSL_ROUTER_1#license install file bootflash:somesortof.lic
Installing...Feature:some_sort_of_feature...Successful:Supported
1/1 licenses were successfully installed
0/1 licenses were existing licenses
0/1 licenses failed to install
CSL_ROUTER_1#
*Jun 14 23:51:16.734: %LICENSE-6-INSTALL: SIP0: licensed: Feature “some_sort_of_feature” 1.0 was installed in this device, UDI=ASR1001:JAE14140XYZ, StoreIndex=2:Primary License Storage
CSL_ROUTER_1#
CSL_ROUTER_1#show license all
CSL_ROUTER_1#sho license all
License Store: Primary License Storage
StoreIndex:  0  Feature: some_sort_of_feature                        Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
mskaneko
Community Member
AESライセンスが入った機器が故障した場合普段はRMA後にライセンスリホストを行いますが、
緊急対応で交換機用部品(保守部品:AISライセンス)を代わりに使用したい場合、
リホスト手順としては、故障品/代替品のS/N、代替品UDI, "Show Version"を添えて変更(リホスト)依頼をJapan TACまで申請すれば良いでしょうか。
発行後のライセンスインストール手順も上記と同様で良いでしょうか。
インストール前に事前にAISライセンスを削除するなどの対応は必要でしょうか?
