download nxos repot from github by using yangsuite
jameslee43329
Hello:
I am trying to download yangsuite repo from github, I got following error..
 cmdline: git clone -v --branch=main -- https://github.com/YangModels/yang.git /ys-data/users/admin/scratch/tmp8l123an1
docker-yangsuite-1  |   stderr: 'Cloning into '/ys-data/users/admin/scratch/tmp8l123an1'...
docker-yangsuite-1  | fatal: unable to access 'https://github.com/YangModels/yang.git/': server certificate verification failed. CAfile: none CRLfile: none
Any help to point to right direction?
Thanks for reply, I already found the problem, Yangsuite is missing root cert from GitHub, certs needs to be installed at
/usr/share/ca-certificates
yawming
Are you trying to install yangsuite ? If so, you may like to  start from here - https://github.com/CiscoDevNet/yangsuite.
Yawming
Thanks for sharing !
