Enum changes in YDK 0.4.0
saalvare
YDK 0.4.0 introduced a couple of changes to enums that are not backward compatible with YDK 0.3.0.  First, the new enum implementation is based on the enum34 module.  This module backports the enum implementation in Python 3.4 to Python 2.4 and later.  Second, enum class names do not use underscores anymore.  These changes make our enum class easier to use and their names more pythonic.
Let's take a look at the Cisco_IOS_XR_clns_isis_cfg model used to configure the IS-IS protocol.  That model makes frequent use of enums.  As an example, let's compare the enum class used to configure the level associated with an adjacency
YDK 0.3.0
Class name: IsisConfigurableLevels_Enum
YDK 0.4.0
Class name: IsisConfigurableLevelsEnum
More importantly, it's now simpler to access the value and name of an enum.  The isis.instances.instance.is_type attribute/leaf is an object of the IsisConfigurableLevelsEnum class.  You can access its attributes using:
isis.instances.instance.is_type.name
Isis.Instances.Instance.is_type.value
This change also paves the road to support Python 3 in the future.
Happy coding!
0 Replies 0
