12-12-2018 12:37 PM
yanghi all,
trying to make some rpc calls using MIB models
for example, trying to use CISCO-PROCESS-MIB and get the cpu history table
i'm sending the following request, using yang-explorer.
<rpc message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<get>
<filter>
<CISCO-PROCESS-MIB xmlns="urn:ietf:params:xml:ns:yang:smiv2:CISCO-PROCESS-MIB">
<cpmCPUHistory/>
</CISCO-PROCESS-MIB>
</filter>
</get>
</rpc>
The result is always http error when using netconf or 404 not found when using restconf
do i have to enable some type of snmp config on the router ? in-order to access stats for memory/CPU etc
i'm not having any issues make other requests, like get interfaces
Solved! Go to Solution.
12-13-2018 12:52 AM
Hi Mando
I've got the same (on csr1000v), until i configure a snmp community. i.e... "snmp-server community test rw" an then "netconf-yang cisco-ia snmp-community-string test".... but unfortunately, the history is empty, means no data. but cpmProcessTable for example works... i assume you want collecting the History, but i dind't found a way to get that.. what you can do is, write a script and collecting from model "cisco-ios-xe-proccess-cpu-oper" via netconf to make your own history statistic.
Cheers
Thom
12-13-2018 12:52 AM
Hi Mando
Cheers
Thom
12-13-2018 06:31 AM
Thanks! Thom
that's exactly what i needed to do, configure the snmp commands
I'm more interested in the cisco-border-ctrlr-call-stats-mib, but i'll keep it in mind regarding the history tables.
