NETCONF/SSH: error: Trustpoint does not have a cert
HI
I have enabled NETCONF on a lab CSR1000V and I am getting message on terminal as below
Also I am unable to connect to it via yang explorer from my Ubuntu machine.
My running config is as below:
R1#sh running-config
Building configuration...
Current configuration : 1482 bytes
! Last configuration change at 20:14:45 UTC Fri Jul 3 2020 by k
version 16.6
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
platform console virtual
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip domain name kj.com
subscriber templating
license udi pid CSR1000V sn 9OG0Q0W7LHE
license boot level ax
diagnostic bootup level minimal
netconf-yang
username k privilege 15 password 0 kk
redundancy
interface GigabitEthernet1
ip address 192.168.1.100 255.255.255.0
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet2
no ip address
shutdown
negotiation auto
no mop enabled
no mop sysid
interface GigabitEthernet3
no ip address
shutdown
negotiation auto
no mop enabled
no mop sysid
virtual-service csr_mgmt
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip ssh version 2
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
control-plane
line con 0
stopbits 1
line vty 0 4
login local
transport input ssh
netconf ssh
end
darrenolive
This issue appears to be a result of self-signed certificates on IOS/IOS-XE platforms expiring on Jan 1st 2020.
https://www.cisco.com/c/en/us/support/docs/security-vpn/public-key-infrastructure-pki/215118-ios-self-signed-certificate-expiration-o.html
The resolution is to upgrade to a newer version of IOS where this issue has been fixed, however I was only testing and able to workaround by changing the time/date to pre Jan 1st 2020.
