Not integer id.
npateriy
Are non integer ids (UUID) supported?
In below sample topologyData1 and topologyData2 works but topologyData3 is failing.
var topologyData1 = {
    nodes: [
        {"id": 0, "x": 410, "y": 100, "name": "12K-1"},
        {"id": 1, "x": 410, "y": 280, "name": "12K-2"}
    links: [
        {"source": 0, "target": 1},
var topologyData2 = {
    nodes: [
        {"id": "0", "x": 410, "y": 100, "name": "12K-1"},
        {"id": "1", "x": 410, "y": 280, "name": "12K-2"}
    links: [
        {"source": "0", "target": "1"},
var topologyData3 = {
    nodes: [
        {"id": "1a", "x": 410, "y": 280, "name": "12K-2"}
    links: [
        {"source": "0", "target": "1a"},
nx.graphic.Topology defaults to using the index instead of the id for identifying link source and destinations, you have to set:
identityKey: 'id',
to make it use the ids which then also works with strings.
identityKey: 'id',
npateriy
Thanks Alexendar.
For future refernce. This works
var topo = new nx.graphic.Topology({
                    identityKey: 'id',
