Ping RPC error with Cisco_IOS_XR_ping_act module
Hello guys,
I see that while using the Cisco_IOS_XR_ping_act module for performing ping tests, the router sets the rpc output field rotate-pattern to a numerical value (0 in my case) , but the yang model/python class expects a boolean value. I am not sure whether the yang model is incorrect or the router is returning a rogue value. Can anyone please confirm.
Mufaddal
YDK Logs
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"><ping xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ping-act">
  <destination>
    <destination>172.16.1.12</destination>
  </destination>
</ping>
</rpc>
2018-02-21 16:42:26,305 - ydk - INFO -
2018-02-21 16:42:26,864 - ydk - INFO - =============Reply payload received from device=============
2018-02-21 16:42:26,864 - ydk - INFO - <?xml version="1.0"?>
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="1">
  <ping-response xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ping-act">
    <ipv4>
      <repeat-count>5</repeat-count>
      <data-size>100</data-size>
      <timeout>2</timeout>
      <pattern>abcd</pattern>
      <rotate-pattern>0</rotate-pattern>
      <replies>
        <reply>
          <reply-index>1</reply-index>
          <result>!</result>
        </reply>
        <reply>
          <reply-index>2</reply-index>
          <result>!</result>
        </reply>
        <reply>
          <reply-index>3</reply-index>
          <result>!</result>
        </reply>
        <reply>
          <reply-index>4</reply-index>
          <result>!</result>
        </reply>
        <reply>
          <reply-index>5</reply-index>
          <result>!</result>
        </reply>
      </replies>
      <hits>5</hits>
      <total>5</total>
      <success-rate>100</success-rate>
      <rtt-min>1</rtt-min>
      <rtt-avg>1</rtt-avg>
      <rtt-max>3</rtt-max>
    </ipv4>
  </ping-response>
</rpc-reply>
2018-02-21 16:42:26,865 - ydk - INFO -
2018-02-21 16:42:26,865 - ydk - ERROR - Data is invalid according to the yang model. Error details: Invalid value "0" in "rotate-pattern" element. Path: '/Cisco-IOS-XR-ping-act:ping/ping-response/ipv4[destination='172.16.1.12']/rotate-pattern'
Additional logs
pip list | grep ydk
ydk (0.7.0)
ydk-models-cisco-ios-xr (6.2.2)
ydk-models-ietf (0.1.4)
ydk-models-openconfig (0.1.4)
ydk-models-service (0.1.0)
XRv9K box version: 6.2.3
abhirame
You are correct. The rotate-pattern should have a boolean value. This is an open bug in XR CSCvh50220. It should be fixed soon.
abhirame
Thank you for the quick response, I think the bug is currently not externally visible
Another related question , is there any other way to do a ping operation for a XR box ?
Please find below a python script which should help you with this:
First:
pip install ncclient
Use below payload:
pl='''<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="101"><ping xmlns="http://cisco.com/ns/yang/Cisco-IOS-XR-ping-act">
  <destination>
  </destination>
</ping>
</rpc>  '''
Then run below script:
from ncclient.operations import RPC, RPCReply
from ncclient import manager
m = manager.connect(
                host='[addrres]',
                port='830',
                username='[username]',
                password='[password]',
                look_for_keys=False,
                allow_agent=False,
                hostkey_verify=False)
class RPC(RPC):
    def _wrap(self, subele):
        return subele
class REPLY_CLS(RPCReply):
    def parse(self):
        self._parsed = True
        return True
RPC.REPLY_CLS = REPLY_CLS
rpc = RPC(m._session, m._device_handler)
pl=pl.replace("101",rpc._id,1)
reply=rpc._request(pl)
print(reply.xml)
