Vagrant sandbox updated with release 0.6.0
saalvare
We announced YDK-Py 0.6.0 a month ago.  You can now give it a try using the Vagrant sandbox available in the ydk-py-samples repo.  What exactly is installed?
vagrant@ydk-py:~$ pip list | grep ydk
ydk                     0.6.0
ydk-models-cisco-ios-xe 16.6.1
ydk-models-cisco-ios-xr 6.2.2
ydk-models-ietf         0.1.3
ydk-models-openconfig   0.1.3
vagrant@ydk-py:~$
This is the 12th release of YDK that we've made available through the Vagrant sandbox.  See the README in the ydk-py-samples repo for some basic instructions on how to instantiate the sandbox and use it to run the hundreds of Cisco IOS XR, OpenConfig and IETF sample apps.
Enjoy!
gjaimes
Level 5
Level 5
Hi Santiago,
How can I get this vagrant sandbox from repository? Thanks in advance.
Here's an example:
$ git clone https://github.com/CiscoDevNet/ydk-py-samples.git
Cloning into 'ydk-py-samples'...
remote: Counting objects: 6418, done.
remote: Total 6418 (delta 0), reused 0 (delta 0), pack-reused 6418
Receiving objects: 100% (6418/6418), 920.08 KiB | 729.00 KiB/s, done.
Resolving deltas: 100% (4319/4319), done.
Checking connectivity... done.
$ cd ydk-py-samples/
$ vagrant box update
==> ydk-py-ubuntu: Checking for updates to 'ydk-py-ubuntu'
    ydk-py-ubuntu: Latest installed version: 0.6.0
    ydk-py-ubuntu: Version constraints:
    ydk-py-ubuntu: Provider: virtualbox
==> ydk-py-ubuntu: Updating 'ydk-py-ubuntu' with provider 'virtualbox' from version
==> ydk-py-ubuntu: '0.6.0' to '0.6.1'...
==> ydk-py-ubuntu: Loading metadata for box 'http://ydk.cisco.com/vagrant/ydk-py-ubuntu/'
==> ydk-py-ubuntu: Adding box 'ydk-py-ubuntu' (v0.6.1) for provider: virtualbox
    ydk-py-ubuntu: Downloading: http://ydk.cisco.com/vagrant/ydk-py-ubuntu/boxes/ydk-py-0.6.1-ubuntu.box
    ydk-py-ubuntu: Calculating and comparing box checksum...
==> ydk-py-ubuntu: Successfully added box 'ydk-py-ubuntu' (v0.6.1) for 'virtualbox'!
$ vagrant up
Bringing machine 'ydk-py-ubuntu' up with 'virtualbox' provider...
==> ydk-py-ubuntu: Importing base box 'ydk-py-ubuntu'...
==> ydk-py-ubuntu: Matching MAC address for NAT networking...
==> ydk-py-ubuntu: Checking if box 'ydk-py-ubuntu' is up to date...
==> ydk-py-ubuntu: Setting the name of the VM: ydk-py-samples_ydk-py-ubuntu_1508875336037_56467
==> ydk-py-ubuntu: Clearing any previously set network interfaces...
==> ydk-py-ubuntu: Preparing network interfaces based on configuration...
    ydk-py-ubuntu: Adapter 1: nat
==> ydk-py-ubuntu: Forwarding ports...
    ydk-py-ubuntu: 22 (guest) => 2222 (host) (adapter 1)
==> ydk-py-ubuntu: Booting VM...
==> ydk-py-ubuntu: Waiting for machine to boot. This may take a few minutes...
    ydk-py-ubuntu: SSH address: 127.0.0.1:2222
    ydk-py-ubuntu: SSH username: vagrant
    ydk-py-ubuntu: SSH auth method: private key
    ydk-py-ubuntu:
    ydk-py-ubuntu: Vagrant insecure key detected. Vagrant will automatically replace
    ydk-py-ubuntu: this with a newly generated keypair for better security.
    ydk-py-ubuntu:
    ydk-py-ubuntu: Inserting generated public key within guest...
    ydk-py-ubuntu: Removing insecure key from the guest if it's present...
    ydk-py-ubuntu: Key inserted! Disconnecting and reconnecting using new SSH key...
==> ydk-py-ubuntu: Machine booted and ready!
==> ydk-py-ubuntu: Checking for guest additions in VM...
==> ydk-py-ubuntu: Mounting shared folders...
    ydk-py-ubuntu: /vagrant => /home/saalvare/src/github.com/111pontes/ydk-py-samples
    ydk-py-ubuntu: /home/vagrant/samples => /home/saalvare/src/github.com/111pontes/ydk-py-samples/samples
    ydk-py-ubuntu: /home/vagrant/projects => /home/saalvare/src/github.com/111pontes/ydk-py-samples/projects
$ vagrant ssh
Welcome to Cisco YDK-Py sandbox (Ubuntu 16.04)
0 packages can be updated.
0 updates are security updates.
Last login: Tue Oct 24 12:26:52 2017
vagrant@ydk-py:~$
Note that the instructions above include the upgrade of the sandbox to use the latest YDK (0.6.1).  The README in the ydk-py-samples repo also provide some guidelines on how to use the sandbox.  HTH.
Thanks a lot. I´ll give it a try !!!
