YangSuite Supported Platforms for Installation
GregoryLeggett
I have found documentation outlining some versions of Python that are supported by YangSuite (e.g. 3.6/3.7/3.8) and some platforms that it can be installed on (e.g. docker, MacOS, WLS).
I would like to know if there is support for newer Python version (i.e. 3.12) and installation on native Windows.  If not, are there plans to support these?
Would open an issue for this request here on the repo https://github.com/CiscoDevNet/yangsuite/issues
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
