How to check module register with UCSD Platofrm
viananth
Where/How to check if the feature is registering with UCSD Platform?
viananth
Enable the “com.cloupia.service.cIM.inframgr=DEBUG” in logging.properties
under /opt/infra/inframgrIf debug is enabled you will find: “jar to be loaded:jar to be loaded:”And then “Loading feature class”If you find you no error “Error while loading feature classes for “  after theabout two lines, then your module/feature is getting added fine
Cisco UCS X-Series Energy Efficiency Offer
