09-18-2018 12:53 AM
I have problems integrating RedHat virtualization into UCS Director, or in other words, creating new virtual RHEV account in UCSD. I get an error "not KVM account".
logs shows connection was somewhat successful, but UCSD returns "connection failed".
I created new account on RHEV, no luck.
API on RHEV works, ansible playbook "ovirt-vms" works for example..
I'm using latest RHEV Version 4.2.6.4-0.1.el7ev
and latest UCSD 6.6.0.0
2018-09-18 06:04:33,926 [ORP-1-35] INFO run(OperationRequestProcessor.java:77) - Executing request... requestId=43116; opName=doFormSubmit 2018-09-18 06:04:33,927 [ORP-1-35] INFO doFormSubmit(APIProvider.java:1247) - FORM SUBMIT custom.add.account.form.Red Hat KVM? 2018-09-18 06:04:33,927 [ORP-1-35] INFO definePage(FormBindings.java:801) - Field = Red Hat KVMgeneric.props.id.podName, LovProviderName = 2018-09-18 06:04:33,928 [ORP-1-35] INFO definePage(FormBindings.java:801) - Field = Red Hat KVMspecific.props.id.policy, LovProviderName = 2018-09-18 06:04:33,928 [ORP-1-35] INFO validatePageData(PhysicalAccountAddForm.java:187) - 2018-09-18 06:04:33,928 [ORP-1-35] INFO validatePageData(PhysicalAccountAddForm.java:192) - Default Pod 2018-09-18 06:04:33,931 [ORP-1-35] INFO newAccountAdded(PhysicalAccountManager.java:57) - Processing new account addition: rhev2 2018-09-18 06:04:33,933 [ORP-1-35] INFO handleAddAccount(AbstractAccountHandler.java:42) - adding account to system 2018-09-18 06:04:33,938 [ORP-1-35] INFO testConnection(RhevAccountTestConnectionHandler.java:22) - Called 2018-09-18 06:04:33,944 [ORP-1-35] INFO <init>(RhevRequest.java:63) - Adding the kvm account url isrhev2.aci.riviera.local 2018-09-18 06:04:33,944 [ORP-1-35] INFO constructUrl(RhevRequest.java:290) - The constructUrl is rhev2.aci.riviera.local 443 2018-09-18 06:04:34,304 [ORP-1-35] INFO is_rhev_version_atleast_four(RhevRequest.java:282) - HttpResponse is 200 2018-09-18 06:04:34,305 [ORP-1-35] INFO execute(RhevRequest.java:100) - method 0 2018-09-18 06:04:34,305 [ORP-1-35] INFO execute(RhevRequest.java:101) - url https://rhev2.aci.riviera.local:443/ovirt-engine/api 2018-09-18 06:04:34,461 [ORP-1-35] INFO sendNotificationEmail(EmailPolicyNotificationEmailSender.java:49) - Send email option is disabled : false 2018-09-18 06:04:34,462 [ORP-1-35] INFO run(OperationRequestProcessor.java:138) - Sending response... requestId=43116
If someone else is looging for documentation: https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ucs-director/kvm-install-guide/6-6/cisco-ucs-director-redhatkvm-mgmt-66/cisco-ucs-director-redhatkvm-mgmt-66_chapter_011.html
11-02-2018 01:35 AM
If someone else is struggling: there is no current support for v4.2. UCSD support redhat 4.1 which is described in compatibility matrix
