06-27-2018 02:41 PM - edited 03-01-2019 06:27 AM
I want to send many objects from UCS Director (Workflow or Custom Workflow Tasks) to my web Site ( Lang PHP).
I tested this request from Rest Client (ARC), but the returned result is ==> "serviceresult: 600" (this is the service request number).
I would like to retrieve the data on the same request, for exemple after invoking Worflow "Proviosnning VM Vmware", I want to recover the data ( like ip address, Vm Name, ...) so i can store in my database.
Thx,
Rami Khili
06-27-2018 02:53 PM
If I understand you correctly you want to retrieve the information per SR _ID.
Show a list of SRs:
http://10.52.249.103/app/api/rest?opName=userAPIGetServiceRequests&opData=
1. {
2. "Service_Request_ID": 115,
3. "Request_Type": "Create VM",
4. "Initiating_User": "demouser",
5. "Group": "DemoGroup",
6. "Catalog_Workflow_Name": "Provision VMware VM",
7. "Initiator_Comments": "",
8. "Request_Time": "Sep 10, 2014 09:39:49 UTC",
9. "Request_Status": "Failed",
10. "Rollback_Type": "",
11. "Catalog": "No"
12. },
Get details of an individual SR:
http://10.52.249.103/app/api/rest?opName=userAPIGetServiceRequestDetails&opData=
1. {
2. "serviceResult":
3. {
4. "requestId": 115,
5. "requestType": 0,
6. "initiatingUser": "demouser",
7. "groupName": "DemoGroup",
8. "requestTime": 1410341989314,
9. "comments": "",
10. "provisionQuantity": 1,
11. "provisionCatalog": "Windows 2008 R2",
12. "provisionVDCName": "CUIC-DEPLOYED-02",
13. "provisionDurationHours": -1
14. },
15. "serviceError": null,
16. "serviceName": "InfraMgr",
17. "opName": "userAPIGetServiceRequestDetails"
18. }
Get SR log:
http://10.52.249.103/app/api/rest?opName=userAPIGetServiceRequestWorkFlow&opData=
1. {
2. "stepId": "Initiated by demouser",
3. "executionStatus": 3,
4. "statusMessage": null,
5. "handlerId": 4,
6. "startedTime": -1,
7. "completedTime": 1410341983118,
8. "validTill": -1,
9. "startAfter": -1
10. },
11. {
12. "stepId": "VM Provision Inputs",
13. "executionStatus": 3,
14. "statusMessage": "",
15. "handlerId": 12,
16. "startedTime": -1,
17. "completedTime": 1410341989488,
18. "validTill": -1,
19. "startAfter": -1
20. },
21. {
22. "stepId": "Budget Allocation",
23. "executionStatus": 3,
24. "statusMessage": "Budget watch is not requested by the group.",
25. "handlerId": 12,
26. "startedTime": -1,
27. "completedTime": 1410341995265,
28. "validTill": -1,
29. "startAfter": -1
30. },
06-27-2018 03:31 PM
Thank you, but when i execute this simple exepmle :
loadLibrary("JSON-JS-Module/JSON-JS-ModuleLibrary");
importPackage(com.cloupia.model.cIM);
importPackage(java.util);
importPackage(java.lang);
importPackage(com.cloupia.service.cIM.inframgr);
importPackage(com.cloupia.lib.util);
var test = "{'name':'1'}";
var resultObj = JSON2.parse(test);
logger.addInfo("result= "+resultObj );
output.return_a = resultObj;
I got this error:
"serviceResponse": null,
"serviceError": "REMOTE_SERVICE_EXCEPTION: The JsonDeserializer IntegerTypeAdapter failed to deserialized json object "return_test" given the type int",
I want to retrieve resultObj.
06-28-2018 04:31 AM
Take a look at this posting
https://communities.cisco.com/docs/DOC-58243
06-28-2018 06:57 AM
Hi Gelbrich,
Thank you for your answer,
I followed the link, but I have no return ( jsonData ) from ucs director. !! he only returns SR in the "serviceResult"
"serviceResult": 685,
"opName": "userAPISubmitWorkflowServiceRequest"
what is the function in opname ? userAPIGetWorkflowServiceRequest, userAPISubmitWorkflowServiceRequest, ??
here is my code:
Code 1:
var jsonData = '{"pool":"test-http-pool","description":"My test virtual server","name":"test-http-virtual","mask":"255.255.255.255","profiles":[{"name":"http","kind":"ltm:virtual:profile"},{"name":"tcp","kind":"ltm:virtual:profile"}],"ipProtocol":"tcp","sourceAddressTranslation":{"type":"automap"},"kind":"tm:ltm:virtual:virtualstate","destination":"1.1.1.3:80"}';
var data = JSON.getJsonElement(jsonData,null);
Code 2 :
var map = new HashMap ();
map.put ("nom", "test-http-virtual");
var data = JSON.javaToJsonString (carte, map.getClass ());
I need to recover the variable jsonData
Thank you in advance
06-28-2018 09:12 AM
I just ran this…
https://172.16.50.51/app/api/rest?opName=userAPIGetServiceRequestWorkFlow&opData=
And the result was this:
{ "serviceResult":{"requestId":3330,"workflowCreated":1530201600207,"submittedTime":1530201600530,"cancelledTime":-1,"cancelledByUser":null,"adminStatus":1,"executionStatus":3,"futureStartTime":1530201600207,"entries":[{"stepId":"Initiated by admin","executionStatus":3,"statusMessage":null,"handlerId":4,"startedTime":-1,"completedTime":1530201603658,"validTill":-1,"startAfter":-1},{"stepId":"RESTfulwebServiceAccess","executionStatus":3,"statusMessage":"","handlerId":12,"startedTime":-1,"completedTime":1530201607831,"validTill":-1,"startAfter":-1},{"stepId":"Parse_Temp","executionStatus":3,"statusMessage":"","handlerId":12,"startedTime":-1,"completedTime":1530201610050,"validTill":-1,"startAfter":-1},{"stepId":"kelvin_to_fahrenheit","executionStatus":3,"statusMessage":"","handlerId":12,"startedTime":-1,"completedTime":1530201616094,"validTill":-1,"startAfter":-1},{"stepId":"Child workflow (GlobalVariables_UPDATE_put_API_Global_var)","executionStatus":3,"statusMessage":"Completed action","handlerId":12,"startedTime":-1,"completedTime":1530201642451,"validTill":-1,"startAfter":-1},{"stepId":"Complete","executionStatus":3,"statusMessage":"Completed successfully.","handlerId":13,"startedTime":-1,"completedTime":1530201642833,"validTill":-1,"startAfter":-1}]}, "serviceError":null, "serviceName":"InfraMgr", "opName":"userAPIGetServiceRequestWorkFlow" }
06-28-2018 10:38 AM
1) In your request you have invoked the workflow first then you have retrieved the workflow data ===> I need to invoke the workflow and retrieve the data at the same time
2) The data in serviceResult is information about the workflow and this is not the case ==> I need the output of the workflow in serviceResult
06-28-2018 11:19 AM
Invoking workflow and getting information on the running workflow would be two separate events.
Infact the checking for workflow status would probably be in a loop with a wait status (~20sec) to see the status of the workflow.
When evoking a workflow it will only return the SR_ID nothing more.
https://communities.cisco.com/docs/DOC-55973
The SR ID is returned and with that number you would have to make further API calls to see status.
