UCS Director Dashboard takes 1 minute to load
Hi Folks
Looking for some urgent help here.
We have recently migrated to UCS Director appliance version 6.6.0 to manager our own private cloud hosted on VMWARE vsphere 5.5
Whenever an enduser logs into the UCSD self service portal it takes almost a minute for dashboard to launch.
Few thing which we have checked.
8 vCPU and 20 GB RAM is allocated to the appliance and is reserved as well.
All the necessary config changes which are mentioned by CISCO in the below link are all applied.
we have almost 3000+ VMs and 1400+ LDAP users.
We did raise a case with CISCO TAC but no luck with them yet.
Also, it was found that whenever the user is waiting for the dashboard to load.. I can see mysqld hitting way above 300% CPU Utilization which I don't see as a positive sign.
Kindly advise.
Parag
1 REPLY 1
Nico.Sauerbrey
Beginner
do you run esx 5.5, Update 3h+ and vCenter 5.5, Update 3g+? otherwise you aint compatible with ucsd 6.6
Content for Community-Ad
